Lenovo ThinkBook 13S-IML Power Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
88
All Time:
268
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace your Lenovo ThinkBook 13S-IML power button.
The Lenovo ThinkBook 13S-IML may have problems if the power button or surrounding area has been damaged, so learning to replace it is an important step. You should consider doing this guide if your device has problems turning on or off, or does so randomly.
Tools
    1. Lenovo ThinkBook 13S-IML Power Button Replacement, Lower Case: step 1, image 1 of 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Lower Case: step 1, image 2 of 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Lower Case: step 1, image 3 of 3
      • Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Lenovo ThinkBook 13S-IML Power Button Replacement, Battery: step 2, image 1 of 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Battery: step 2, image 2 of 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Battery: step 2, image 3 of 3
      • Caution: Make sure that your battery is discharged below 25% capacity.
      • Remove the four 4 mm-long Phillips #00 screws securing the battery.
      • Use a spudger to push the battery connector out of its socket.
      • Caution: This may take a while. Be careful, and do not try and push with much force.
      • Remove the battery from the computer by pulling it up and out.
      Ask FixBot
    1. Lenovo ThinkBook 13S-IML Power Button Replacement, Power Button: step 3, image 1 of 1
      • Remove the six M2.5 x 5 Phillips #00 screws that secure the upper case hinges first.
      • Remove the two remaining M2 x 5 Phillips #00 screws and set them aside.
      Ask FixBot
    2. Lenovo ThinkBook 13S-IML Power Button Replacement: step 4, image 1 of 2 Lenovo ThinkBook 13S-IML Power Button Replacement: step 4, image 2 of 2
      • Carefully open laptop to pull upper case hinges apart from the board.
      • It may be easier to open the laptop rather than pulling open the hinges.
      Ask FixBot
    3. Lenovo ThinkBook 13S-IML Power Button Replacement: step 5, image 1 of 1
      • Remove the 2 M2.0 x 3.5mm Phillips #00 screws.
      • Locate the larger ZIF connector and lift the circled locking flap, then pull the cable out of its socket.
      • Proceed to lift the USB board out.
      Ask FixBot
    4. Lenovo ThinkBook 13S-IML Power Button Replacement: step 6, image 1 of 3 Lenovo ThinkBook 13S-IML Power Button Replacement: step 6, image 2 of 3 Lenovo ThinkBook 13S-IML Power Button Replacement: step 6, image 3 of 3
      • Carefully pull up the plastic power button cover.
      • Disengage the thin ZIF connector by flipping up the locking flap and pulling the cable out of it's socket.
      • Proceed to remove the power button.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Samson BeSerra
289 Reputation
3 Guides authored
UW Tacoma, Team E-2, Rose Winter 2026 Member of UW Tacoma, Team E-2, Rose Winter 2026
UWT-ROSE-W26SEG2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 88
All Time: 268
