Lenovo ThinkBook 13S-IML Fans Replacement
    1. Lenovo ThinkBook 13S-IML Fans Replacement, Lower Case: step 1, image 1 of 3 Lenovo ThinkBook 13S-IML Fans Replacement, Lower Case: step 1, image 2 of 3 Lenovo ThinkBook 13S-IML Fans Replacement, Lower Case: step 1, image 3 of 3
      • Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Lenovo ThinkBook 13S-IML Fans Replacement, Battery: step 2, image 1 of 3 Lenovo ThinkBook 13S-IML Fans Replacement, Battery: step 2, image 2 of 3 Lenovo ThinkBook 13S-IML Fans Replacement, Battery: step 2, image 3 of 3
      • Caution: Make sure that your battery is discharged below 25% capacity.
      • Remove the four 4 mm-long Phillips #00 screws securing the battery.
      • Use a spudger to push the battery connector out of its socket.
      • Caution: This may take a while. Be careful, and do not try and push with much force.
      • Remove the battery from the computer by pulling it up and out.
      Ask FixBot
    1. Lenovo ThinkBook 13S-IML Fans Replacement, Fans: step 3, image 1 of 3 Lenovo ThinkBook 13S-IML Fans Replacement, Fans: step 3, image 2 of 3 Lenovo ThinkBook 13S-IML Fans Replacement, Fans: step 3, image 3 of 3
      • Detach the two sliding fan connectors from the system board by gently pulling them out of their sockets.
      • Use a screwdriver to unscrew the five 3.5 mm Phillips #00 screws that secure the fans in place.
      • Carefully lift the fans out of the system board.
      Ask FixBot
Sierra Vang
73 Reputation
1 Guide authored
UW Tacoma, Team E-2, Rose Winter 2026 Member of UW Tacoma, Team E-2, Rose Winter 2026
UWT-ROSE-W26SEG2
4 Members
44 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 41
All Time: 130
