Lenovo Tab S8 Power Button Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
115
All Time:
2,634
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you have to forcefully press the power button multiple times to get your screen to come on, follow these simple steps to replace the power button.
Tools
  • Spudger
    4.9
  • iFixit Opening Tool
    4.8
    1. Lenovo Tab S8 Power Button Replacement, Power Button: step 1, image 1 of 3 Lenovo Tab S8 Power Button Replacement, Power Button: step 1, image 2 of 3 Lenovo Tab S8 Power Button Replacement, Power Button: step 1, image 3 of 3
      • Make sure the device is powered off
      • Gently insert a spudger into one of the bottom corners between the screen and body case. Gently slide the spudger along the inside of the crack to pry the case open
      • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
      Ask FixBot
    2. Lenovo Tab S8 Power Button Replacement: step 2, image 1 of 3 Lenovo Tab S8 Power Button Replacement: step 2, image 2 of 3 Lenovo Tab S8 Power Button Replacement: step 2, image 3 of 3
      • Gently lift the clear-yellow rubber flap from the plastic pegs with a plastic opening tool.
      • The rubber flap secures the button to the casing, and it falls out easily.
      Ask FixBot
James Albu
608 Reputation
2 Guides authored
USF Tampa, Team 3-6, Eyestone Fall 2015 Member of USF Tampa, Team 3-6, Eyestone Fall 2015
USFT-EYESTONE-F15S3G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 115
All Time: 2,634
