Lenovo Tab S8 Camera Replacement
    1. Lenovo Tab S8 Camera Replacement, Battery: step 1, image 1 of 2 Lenovo Tab S8 Camera Replacement, Battery: step 1, image 2 of 2
      • Make sure the device is powered off.
      • Gently insert a spudger into one of the bottom corners between the screen and body case.
      • Slide the spudger along the inside of the crack in order to pry the case open.
      • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
      Ask FixBot
    2. Lenovo Tab S8 Camera Replacement: step 2, image 1 of 3 Lenovo Tab S8 Camera Replacement: step 2, image 2 of 3 Lenovo Tab S8 Camera Replacement: step 2, image 3 of 3
      • After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
      • Using screwdriver bits that do not fit in the screw head might strip the screw and render it unusable.
      • Remove the tape by gently scraping the edges up with the spudger.
      Ask FixBot
    3. Lenovo Tab S8 Camera Replacement: step 3, image 1 of 3 Lenovo Tab S8 Camera Replacement: step 3, image 2 of 3 Lenovo Tab S8 Camera Replacement: step 3, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Before removing the battery, be sure to disconnect the ribbon cables underneath it. The cables might stick to the battery during removal and cause damage.
      • Gently lift the flaps on the four ZIF connectors to disconnect the cables.
      • Use the plastic card to gently pry the battery from the device.
      • There may be glue holding the battery to the device. Use the spudger to detach any glue while the battery is partially raised by the card.
      Ask FixBot
    1. Lenovo Tab S8 Camera Replacement, Camera: step 4, image 1 of 3 Lenovo Tab S8 Camera Replacement, Camera: step 4, image 2 of 3 Lenovo Tab S8 Camera Replacement, Camera: step 4, image 3 of 3
      Buy
      • Use a plastic opening tool to gently pry the end of the camera's black ribbon cable (opposite the camera lens) off of the motherboard.
      • Once the cable is free, use tweezers to pull the camera from the body.
      • The camera may be stuck in place with a piece rubber foam. Take care to not damage the camera by applying too much pressure.
      Ask FixBot
Thomas Rill
338 Reputation
2 Guides authored
USF Tampa, Team 3-6, Eyestone Fall 2015 Member of USF Tampa, Team 3-6, Eyestone Fall 2015
USFT-EYESTONE-F15S3G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 93
All Time: 1,089
