Lenovo Tab 2 A8 MicroUSB Charging Port Replacement
    1. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Removing the Back Panel: step 1, image 1 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Removing the Back Panel: step 1, image 2 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Removing the Back Panel: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Place the tablet face down on a soft, stable surface that will protect the screen.
      • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
      • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
      • If the seal covering the screw has already been removed, please proceed to the next step in the process.
      • As the screw is small, you may wish to extract it using a pair of tweezers.
      Ask FixBot
    2. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: step 2, image 1 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: step 2, image 2 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: step 2, image 3 of 3
      • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
      • Some force may be required initially to pry the back cover off.
      • Note that the button tabs for this device are loose inside the case and will fall out when opening.
      Ask FixBot
    1. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Motherboard: step 3, image 1 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Motherboard: step 3, image 2 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Motherboard: step 3, image 3 of 3
      Buy
      • Using the Phillips #000 screwdriver, remove the four M1.4 × 2.5 screws holding the motherboard in place.
      • Because the screws are small, it is a good idea to remove them with a pair of tweezers.
      Ask FixBot
    2. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: step 4, image 1 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: step 4, image 2 of 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: step 4, image 3 of 3
      • Remove the M1.4 × 2.5 screw securing the battery lead to the battery with the Phillips #000 screwdriver.
      • With a pair of tweezers, gently move the battery lead so it will not obstruct the motherboard.
      • With a pair of tweezers, carefully unplug the strip connecting the screen to the motherboard.
      • The strip connecting the screen to the motherboard is firmly in place and may require some careful use of strength to unplug it.
      Ask FixBot
    3. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: step 5, image 1 of 1
      • Remove the motherboard by lifting the top edge and pulling outward to free it from the small tabs that hold it in place.
      • The small tabs can be broken if the motherboard is pried up too forcefully.
      • The button tabs are fastened to the motherboard by a small adhesive strip. Take care in removing the motherboard to avoid tearing the wires.
      Ask FixBot
    1. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, MicroUSB Charging Port: step 6, image 1 of 1
      Buy
      • Flip the motherboard on to its back side.
      • The back side has less components on that side. You should see more green color than the front side.
      • Desolder the six soldering joints around the charging port.
      • With a set of tweezers, gentle lift the charging port off motherboard.
      Ask FixBot
3 other people completed this guide.
Melanie Turner
161 Reputation
1 Guide authored
IUPUI, Team 2-4, Baechle Spring 2017 Member of IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
4 Members
51 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 59
All Time: 13,958
