Lenovo Tab 2 A8 Front-Facing Camera Replacement
    1. Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: step 1, image 1 of 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: step 1, image 2 of 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Place the tablet face down on a soft, stable surface that will protect the screen.
      • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
      • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
      • If the seal covering the screw has already been removed, please proceed to the next step in the process.
      • As the screw is small, you may wish to extract it using a pair of tweezers.
      Ask FixBot
    2. Lenovo Tab 2 A8 Front-Facing Camera Replacement: step 2, image 1 of 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement: step 2, image 2 of 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement: step 2, image 3 of 3
      • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
      • Some force may be required initially to pry the back cover off.
      • Note that the button tabs for this device are loose inside the case and will fall out when opening.
      Ask FixBot
    1. Lenovo Tab 2 A8 Front-Facing Camera Replacement, Front-Facing Camera: step 3, image 1 of 1
      Buy
      • Using tweezers, peel off the anti-static sticker from the camera connection port.
      Ask FixBot
    2. Lenovo Tab 2 A8 Front-Facing Camera Replacement: step 4, image 1 of 1
      • Lift the camera out of its socket in the motherboard. Then, using tweezers to grasp the camera connector, carefully pull the connector horizontally out of the port.
      • Be aware that the camera connector will be firmly lodged in the port. When successfully removed, the top side of the port pops up.
      Ask FixBot
    3. Lenovo Tab 2 A8 Front-Facing Camera Replacement: step 5, image 1 of 1
      • Using tweezers to grasp the camera connector, lift the camera out of its socket.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 1,395
