Lenovo Tab 2 A8 Battery Replacement
    1. Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: step 1, image 1 of 3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: step 1, image 2 of 3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Place the tablet face down on a soft, stable surface that will protect the screen.
      • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
      • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
      • If the seal covering the screw has already been removed, please proceed to the next step in the process.
      • As the screw is small, you may wish to extract it using a pair of tweezers.
      Ask FixBot
    2. Lenovo Tab 2 A8 Battery Replacement: step 2, image 1 of 3 Lenovo Tab 2 A8 Battery Replacement: step 2, image 2 of 3 Lenovo Tab 2 A8 Battery Replacement: step 2, image 3 of 3
      • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
      • Some force may be required initially to pry the back cover off.
      • Note that the button tabs for this device are loose inside the case and will fall out when opening.
      Ask FixBot
    1. Lenovo Tab 2 A8 Battery Replacement, Battery: step 3, image 1 of 2 Lenovo Tab 2 A8 Battery Replacement, Battery: step 3, image 2 of 2
      Buy
      • Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
      • With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
      Ask FixBot
    2. Lenovo Tab 2 A8 Battery Replacement: step 4, image 1 of 3 Lenovo Tab 2 A8 Battery Replacement: step 4, image 2 of 3 Lenovo Tab 2 A8 Battery Replacement: step 4, image 3 of 3
      • Working your way around the edge of the battery, pry out the battery using a plastic opening tool
      • Be aware that the battery is held in by double-sided tape on the underside
      Ask FixBot
5 other people completed this guide.
2 Guide Comments
Thanks... but where do we find a replacement battery?
sebtrudel - Reply Share
I fixit might have a replacement battery
storm builder - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 53
All Time: 12,968
