Lenovo N23 Keyboard Replacement
    1. Lenovo N23 Keyboard Replacement, Removing the back cover: step 1, image 1 of 1
      • Power down the Chromebook before starting the repair.
      • Opening the Chromebook voids the manufacturer warranty.
      • Flip the Chromebook so that the bottom is facing upwards.
      • Use a Phillips #1 screwdriver to remove the eight 6.6 mm screws in the bottom.
      Ask FixBot
    2. Lenovo N23 Keyboard Replacement, Opening up the keyboard: step 2, image 1 of 1
      • Flip the Chromebook over and open the lid.
      • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
      • Be careful of the tabs on the inside of the keyboard and Chromebook, these could break too.
      • Run the plastic tool along the seam, popping up the keyboard until you can freely lift up the keyboard.
      • It is normal for the tabs to make loud popping sounds when released. The corner tabs are harder to remove and will make a louder click when released.
      Ask FixBot
    3. Lenovo N23 Keyboard Replacement, Releasing the keyboard from the motherboard: step 3, image 1 of 1
      • Once the keyboard is released, grab the top two corners closest to the lid and slowly lift the keyboard up.
      • Do not lift the keyboard too quickly, or you might break the two cables that connect the keyboard to the motherboard.
      • The motherboard is now exposed. DO NOT use any tools with metal or you may short circuit and fry the motherboard.
      • Disconnect the cables by lifting up on the retaining tabs on the blank ZIF connectors.
      • Slowly pull the cables up and out of the connectors.
      Ask FixBot
    4. Lenovo N23 Keyboard Replacement: step 4, image 1 of 1
      • Lift the keyboard up and off of the back retainers completely removing the keyboard from the Chromebook.
      Ask FixBot
2 other people completed this guide.
Robin Mores
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 62
All Time: 1,868
