Lenovo N22 Chromebook Individual Key Replacement
    1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: step 1, image 1 of 1
      • Power down the chromebook before starting this process.
      • Loosen the key by prying on the edge of the key with the plastic opening tool.
      Ask FixBot
    2. Lenovo N22 Chromebook Individual Key Replacement: step 2, image 1 of 2 Lenovo N22 Chromebook Individual Key Replacement: step 2, image 2 of 2
      • Remove the key from the keyboard by prying the key off with the opener or with your finger.
      • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
      • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
      Ask FixBot
13 other people completed this guide.
Jackson Tucker
872 Reputation
3 Guides authored
Cal Poly, Team S21-G1, Livingston Spring 2017 Member of Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Members
84 Guides authored
6 Guide Comments
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - Reply Share
Where can I order individual keys?
Mallory Montreuil - Reply Share
He tried to turn it on but it did not work
Clayton Sensing - Reply Share
I took it off and now it broken he he
BRENNEN FIRKUS - Reply Share
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 44
All Time: 16,100
