Lenovo Miix 2 Vibrating Cable Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
74
All Time:
581
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide instructs the user how to replace the vibrating cable located in the Lenovo Miix 2 8 tablet. This process is important in case the vibrating function of the device no longer works and needs to be replaced to return to normal functionality.
Parts
Tools
    1. Lenovo Miix 2 Vibrating Cable Replacement, Battery: step 1, image 1 of 2 Lenovo Miix 2 Vibrating Cable Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
      • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
      Ask FixBot
    2. Lenovo Miix 2 Vibrating Cable Replacement: step 2, image 1 of 2 Lenovo Miix 2 Vibrating Cable Replacement: step 2, image 2 of 2
      • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
      Ask FixBot
    3. Lenovo Miix 2 Vibrating Cable Replacement: step 3, image 1 of 2 Lenovo Miix 2 Vibrating Cable Replacement: step 3, image 2 of 2
      • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
      Ask FixBot
    4. Lenovo Miix 2 Vibrating Cable Replacement: step 4, image 1 of 2 Lenovo Miix 2 Vibrating Cable Replacement: step 4, image 2 of 2
      • Remove the battery by prying up with your fingers or a plastic opening tool.
      Ask FixBot
    1. Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: step 5, image 1 of 3 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: step 5, image 2 of 3 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the vibrator cable which is connected with a white connector head to the motherboard, by gently lifting on the connector head with tweezers.
      • Remove the vibrator head by following the black and wire cable from the motherboard to where the head is located.
      Ask FixBot
Max Rozema
157 Reputation
2 Guides authored
IUPUI, Team S3-G1, Harley Spring 2019 Member of IUPUI, Team S3-G1, Harley Spring 2019
IUPUI-HARLEY-S19S3G1
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 74
All Time: 581
