Lenovo Miix 2 Front Facing Camera Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
101
All Time:
2,387
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide goes over the steps to remove the front camera from the tablet.
Tools
    1. Lenovo Miix 2 Front Facing Camera Replacement, Battery: step 1, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
      • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
      Ask FixBot
    2. Lenovo Miix 2 Front Facing Camera Replacement: step 2, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement: step 2, image 2 of 2
      • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
      Ask FixBot
    3. Lenovo Miix 2 Front Facing Camera Replacement: step 3, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement: step 3, image 2 of 2
      • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
      Ask FixBot
    4. Lenovo Miix 2 Front Facing Camera Replacement: step 4, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement: step 4, image 2 of 2
      • Remove the battery by prying up with your fingers or a plastic opening tool.
      Ask FixBot
    1. Lenovo Miix 2 Front Facing Camera Replacement, Speakers: step 5, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement, Speakers: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
      • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
      Ask FixBot
    1. Lenovo Miix 2 Front Facing Camera Replacement, Motherboard: step 6, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement, Motherboard: step 6, image 2 of 2
      • Locate the LCD cable connector and gently pry it directly up with a spudger.
      Ask FixBot
    2. Lenovo Miix 2 Front Facing Camera Replacement: step 7, image 1 of 3 Lenovo Miix 2 Front Facing Camera Replacement: step 7, image 2 of 3 Lenovo Miix 2 Front Facing Camera Replacement: step 7, image 3 of 3
      • Remove the 5 ribbon cables. use the tip of the spudger to flip up the retaining flap, making sure to lift on the hinge and not the connector itself, then remove the cable from the connector.
      • The flaps and connectors vary in color.
      • Once the hinge has been lifted, the ribbon cable should take no force to remove.
      Ask FixBot
    3. Lenovo Miix 2 Front Facing Camera Replacement: step 8, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement: step 8, image 2 of 2
      Buy
      • Remove the 3 antenna cables using the tweezers by slowly pulling up.
      • We found that pulling up and twisting a bit works best.
      Ask FixBot
    4. Lenovo Miix 2 Front Facing Camera Replacement: step 9, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement: step 9, image 2 of 2
      • Remove the 4 1.6mm screws with a J0 head.
      Ask FixBot
    5. Lenovo Miix 2 Front Facing Camera Replacement: step 10, image 1 of 2 Lenovo Miix 2 Front Facing Camera Replacement: step 10, image 2 of 2
      • Remove the red and black cable using the tweezers by gently pulling the connector to the right.
      Ask FixBot
    6. Lenovo Miix 2 Front Facing Camera Replacement: step 11, image 1 of 1
      • Lift the motherboard out of the tablet's case.
      Ask FixBot
    1. Lenovo Miix 2 Front Facing Camera Replacement, Front Facing Camera: step 12, image 1 of 1
      Buy
      • Disconnect the ribbon cable using the tweezers
      Ask FixBot
    2. Lenovo Miix 2 Front Facing Camera Replacement: step 13, image 1 of 1
      • Lift the camera up with tweezers to remove it
      Ask FixBot
3 other people completed this guide.
Diana Chiu
675 Reputation
4 Guides authored
Cal Poly, Team 5-8, Maness Spring 2015 Member of Cal Poly, Team 5-8, Maness Spring 2015
CPSU-MANESS-S15S5G8
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 101
All Time: 2,387
