Lenovo Miix 2 Battery Replacement
Views: 9.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
126
All Time:
9,760
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide explains how to quickly open the back case of the Miix 2 using spudgers and a screwdriver.
Tools
    1. Lenovo Miix 2 Battery Replacement, Battery: step 1, image 1 of 2 Lenovo Miix 2 Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
      • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
      Ask FixBot
    2. Lenovo Miix 2 Battery Replacement: step 2, image 1 of 2 Lenovo Miix 2 Battery Replacement: step 2, image 2 of 2
      • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
      Ask FixBot
    3. Lenovo Miix 2 Battery Replacement: step 3, image 1 of 2 Lenovo Miix 2 Battery Replacement: step 3, image 2 of 2
      • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
      Ask FixBot
    4. Lenovo Miix 2 Battery Replacement: step 4, image 1 of 2 Lenovo Miix 2 Battery Replacement: step 4, image 2 of 2
      • Remove the battery by prying up with your fingers or a plastic opening tool.
      Ask FixBot
3 other people completed this guide.
Nicolas Jones
395 Reputation
1 Guide authored
Cal Poly, Team 5-8, Maness Spring 2015 Member of Cal Poly, Team 5-8, Maness Spring 2015
CPSU-MANESS-S15S5G8
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 126
All Time: 9,760
