Lenovo Legion Y7000P Left Fan Replacement
    1. Lenovo Legion Y7000P Left Fan Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo Legion Y7000P Left Fan Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Lenovo Legion Y7000P Left Fan Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. Lenovo Legion Y7000P Left Fan Replacement, Unfasten the back cover: step 3, image 1 of 2 Lenovo Legion Y7000P Left Fan Replacement, Unfasten the back cover: step 3, image 2 of 2
      • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
      • Five 11.5 mm‑long screws
      • Six 4.7 mm-long screws
      Ask FixBot
    3. Lenovo Legion Y7000P Left Fan Replacement, Insert an opening pick: step 4, image 1 of 2 Lenovo Legion Y7000P Left Fan Replacement, Insert an opening pick: step 4, image 2 of 2
      • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
      Ask FixBot
    4. Lenovo Legion Y7000P Left Fan Replacement, Release the back cover's clips: step 5, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement, Release the back cover's clips: step 5, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement, Release the back cover's clips: step 5, image 3 of 3
      • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
      • Keep the pick angled upwards while sliding to help release the clips.
      • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
      Ask FixBot
    5. Lenovo Legion Y7000P Left Fan Replacement: step 6, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement: step 6, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement: step 6, image 3 of 3
      • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
      Ask FixBot
    6. Lenovo Legion Y7000P Left Fan Replacement, Remove the back cover: step 7, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement, Remove the back cover: step 7, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover.
      Ask FixBot
    7. Lenovo Legion Y7000P Left Fan Replacement, Reassembly information: step 8, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement, Reassembly information: step 8, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement, Reassembly information: step 8, image 3 of 3
      • During reassembly:
      • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
      • Press down firmly around the perimeter of the back cover to engage all the clips.
      Ask FixBot
    1. Lenovo Legion Y7000P Left Fan Replacement, Heat the black cover: step 9, image 1 of 2 Lenovo Legion Y7000P Left Fan Replacement, Heat the black cover: step 9, image 2 of 2
      • A stiff, black cover runs across the heatsink and fans.
      • Removing the cover makes repairs much easier, but isn't required. If you don't want to remove the cover, you can roll it onto itself to keep it out of the way and skip the next two steps.
      • Heat an iOpener and apply it to the cover for two minutes.
      • You can also use a hair dryer. Follow this guide for more instructions.
      Ask FixBot
    2. Lenovo Legion Y7000P Left Fan Replacement, Remove the cover: step 10, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement, Remove the cover: step 10, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement, Remove the cover: step 10, image 3 of 3
      • Gently peel up and remove the black cover.
      • During reassembly, press the cover back into place using the residual adhesive.
      Ask FixBot
    3. Lenovo Legion Y7000P Left Fan Replacement, Disconnect the battery: step 11, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement, Disconnect the battery: step 11, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement, Disconnect the battery: step 11, image 3 of 3
      • Use the flat end of a spudger to push the battery connector straight out of its socket.
      • Push the tab on top of the battery connector, not the wires themselves.
      Ask FixBot
    1. Lenovo Legion Y7000P Left Fan Replacement, Disconnect the fan cable: step 12, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement, Disconnect the fan cable: step 12, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement, Disconnect the fan cable: step 12, image 3 of 3
      • The left fan will be on your right-hand side, as the laptop is laying upside down.
      • Use the point of a spudger to push on alternating sides of the left fan cable connector to "walk" it out of its socket.
      Ask FixBot
    2. Lenovo Legion Y7000P Left Fan Replacement, Unclip the display cable: step 13, image 1 of 2 Lenovo Legion Y7000P Left Fan Replacement, Unclip the display cable: step 13, image 2 of 2
      • Use the point of a spudger to guide the display cable out of the clips on the bottom edge of the left fan.
      Ask FixBot
    3. Lenovo Legion Y7000P Left Fan Replacement, Unfasten the left fan: step 14, image 1 of 2 Lenovo Legion Y7000P Left Fan Replacement, Unfasten the left fan: step 14, image 2 of 2
      • Use a Phillips screwdriver to remove the two 5.7 mm‑long screws securing the left fan.
      Ask FixBot
    4. Lenovo Legion Y7000P Left Fan Replacement, Remove the left fan: step 15, image 1 of 3 Lenovo Legion Y7000P Left Fan Replacement, Remove the left fan: step 15, image 2 of 3 Lenovo Legion Y7000P Left Fan Replacement, Remove the left fan: step 15, image 3 of 3
      • Lift the top edge of the left fan.
      • Slide the left fan cable out from under the display cable and remove the fan.
      • During reassembly, make sure the fan cable is under the display cable before securing the fan.
      Ask FixBot
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
199,886 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,700 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 107
All Time: 2,712
