Lenovo Legion Y7000P Battery Replacement
    1. Lenovo Legion Y7000P Battery Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo Legion Y7000P Battery Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Lenovo Legion Y7000P Battery Replacement, Flip your laptop over: step 2, image 1 of 1
      • Flip your laptop over so the rubber feet are facing up.
      Ask FixBot
    2. Lenovo Legion Y7000P Battery Replacement, Unfasten the back cover: step 3, image 1 of 2 Lenovo Legion Y7000P Battery Replacement, Unfasten the back cover: step 3, image 2 of 2
      • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
      • Five 11.5 mm‑long screws
      • Six 4.7 mm-long screws
      Ask FixBot
    3. Lenovo Legion Y7000P Battery Replacement, Insert an opening pick: step 4, image 1 of 2 Lenovo Legion Y7000P Battery Replacement, Insert an opening pick: step 4, image 2 of 2
      • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
      Ask FixBot
    4. Lenovo Legion Y7000P Battery Replacement, Release the back cover's clips: step 5, image 1 of 3 Lenovo Legion Y7000P Battery Replacement, Release the back cover's clips: step 5, image 2 of 3 Lenovo Legion Y7000P Battery Replacement, Release the back cover's clips: step 5, image 3 of 3
      • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
      • Keep the pick angled upwards while sliding to help release the clips.
      • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
      Ask FixBot
    5. Lenovo Legion Y7000P Battery Replacement: step 6, image 1 of 3 Lenovo Legion Y7000P Battery Replacement: step 6, image 2 of 3 Lenovo Legion Y7000P Battery Replacement: step 6, image 3 of 3
      • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
      Ask FixBot
    6. Lenovo Legion Y7000P Battery Replacement, Remove the back cover: step 7, image 1 of 3 Lenovo Legion Y7000P Battery Replacement, Remove the back cover: step 7, image 2 of 3 Lenovo Legion Y7000P Battery Replacement, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover.
      Ask FixBot
    7. Lenovo Legion Y7000P Battery Replacement, Reassembly information: step 8, image 1 of 3 Lenovo Legion Y7000P Battery Replacement, Reassembly information: step 8, image 2 of 3 Lenovo Legion Y7000P Battery Replacement, Reassembly information: step 8, image 3 of 3
      • During reassembly:
      • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
      • Press down firmly around the perimeter of the back cover to engage all the clips.
      Ask FixBot
    1. Lenovo Legion Y7000P Battery Replacement, Heat the black cover: step 9, image 1 of 2 Lenovo Legion Y7000P Battery Replacement, Heat the black cover: step 9, image 2 of 2
      • A stiff, black cover runs across the heatsink and fans.
      • Removing the cover makes repairs much easier, but isn't required. If you don't want to remove the cover, you can roll it onto itself to keep it out of the way and skip the next two steps.
      • Heat an iOpener and apply it to the cover for two minutes.
      • You can also use a hair dryer. Follow this guide for more instructions.
      Ask FixBot
    2. Lenovo Legion Y7000P Battery Replacement, Remove the cover: step 10, image 1 of 3 Lenovo Legion Y7000P Battery Replacement, Remove the cover: step 10, image 2 of 3 Lenovo Legion Y7000P Battery Replacement, Remove the cover: step 10, image 3 of 3
      • Gently peel up and remove the black cover.
      • During reassembly, press the cover back into place using the residual adhesive.
      Ask FixBot
    3. Lenovo Legion Y7000P Battery Replacement, Disconnect the battery: step 11, image 1 of 3 Lenovo Legion Y7000P Battery Replacement, Disconnect the battery: step 11, image 2 of 3 Lenovo Legion Y7000P Battery Replacement, Disconnect the battery: step 11, image 3 of 3
      • Use the flat end of a spudger to push the battery connector straight out of its socket.
      • Push the tab on top of the battery connector, not the wires themselves.
      Ask FixBot
    1. Lenovo Legion Y7000P Battery Replacement, Unfasten the battery: step 12, image 1 of 2 Lenovo Legion Y7000P Battery Replacement, Unfasten the battery: step 12, image 2 of 2
      • Use a Phillips screwdriver to remove the five 5.7 mm‑long screws securing the battery.
      Ask FixBot
    2. Lenovo Legion Y7000P Battery Replacement, Remove the battery: step 13, image 1 of 2 Lenovo Legion Y7000P Battery Replacement, Remove the battery: step 13, image 2 of 2
      • Remove the battery.
      Ask FixBot
Check your repair by running hardware tests with Lenovo Diagnostics.
For optimal performance, calibrate your newly installed battery after completing this guide.
2 other people completed this guide.
Spencer Day
199,958 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
81,560 Guides authored
1 Guide Comment
Worked great! My laptop looks a little different, and I didn’t have a black cover to worry about, but the essentials of this guide were super helpful.
DrP - Reply Share
Past 24 Hours: 2
Past 7 Days: 38
Past 30 Days: 230
All Time: 5,865
