Lenovo Legion 5 17ACH6H RAM Replacement
    1. Lenovo Legion 5 17ACH6H RAM Replacement, RAM: step 1, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement, RAM: step 1, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement, RAM: step 1, image 3 of 3
      • Use the Phillips #1 screwdriver to remove the ten screws on the back panel.
      • Four 4.6 mm PH1 screws
      • Six 12.8 mm PH1 screws
      Ask FixBot
    2. Lenovo Legion 5 17ACH6H RAM Replacement: step 2, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 2, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 2, image 3 of 3
      • Insert the rounded side of the opening pick on the lower right of the back panel.
      • Apply light pressure downwards to release the clip.
      • Slide the opening pick along the lower back side of the panel to release the remaining clips.
      Ask FixBot
    3. Lenovo Legion 5 17ACH6H RAM Replacement: step 3, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 3, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 3, image 3 of 3
      • Insert the opening pick on the right side of the panel (along the ports) and slide it across to release the pins.
      • Repeat this step on the left side of the panel.
      Ask FixBot
    4. Lenovo Legion 5 17ACH6H RAM Replacement: step 4, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 4, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 4, image 3 of 3
      • Slide the pick in the vent near the USB C port.
      • Rotate the pick so it is on the top part of the vent.
      • Slide the pick across the top side of the vent
      • The laptop can be held vertically, so the process is much easier.
      • Repeat this step on the other side vent near the USB A port.
      Ask FixBot
    5. Lenovo Legion 5 17ACH6H RAM Replacement: step 5, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 5, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 5, image 3 of 3
      • Grab the back panel and lift it to remove it from the chassis.
      • Before completely lifting the back panel, the panel should be pushed a little bit away from you. This is to prevent the panel from getting stuck with the IO ports.
      Ask FixBot
    6. Lenovo Legion 5 17ACH6H RAM Replacement: step 6, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 6, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 6, image 3 of 3
      • Use the pointed tip of a spudger to carefully push on each side of the connector.
      • Use the flat side of the spudger at the top of the battery connector to completely push it out.
      • Pull the cable by the connector and not the wires to move it out of the way.
      • It is important to disconnect the battery since touching the components with the battery connected can short-circuit the device. This could cause damage to the components and yourself.
      Ask FixBot
    7. Lenovo Legion 5 17ACH6H RAM Replacement: step 7, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 7, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 7, image 3 of 3
      • Place the flat side of the spudger between the RAM shield (right) and the metal plate (left) at a 45-degree angle.
      • Pry open the bottom part of the metal plate by moving the spudger toward the RAM shield.
      Ask FixBot
    8. Lenovo Legion 5 17ACH6H RAM Replacement: step 8, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 8, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 8, image 3 of 3
      • Place the flat side of the spudger between the fan (right) and the metal plate (left).
      • Pry open the top part of the metal plate by moving the spudger toward the fan.
      Ask FixBot
    9. Lenovo Legion 5 17ACH6H RAM Replacement: step 9, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 9, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 9, image 3 of 3
      • Grab both sides of the metal plate to lift it off the clips.
      Ask FixBot
    10. Lenovo Legion 5 17ACH6H RAM Replacement: step 10, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 10, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 10, image 3 of 3
      • With both thumbs, push the clips outward.
      • Gently slide the RAM module out of the socket to remove it.
      Ask FixBot
    11. Lenovo Legion 5 17ACH6H RAM Replacement: step 11, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 11, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 11, image 3 of 3
      • Repeat step 10 to remove the top module.
      • The laptop was rotated 180 degrees, which is why it is facing the camera.
      Ask FixBot
    12. Lenovo Legion 5 17ACH6H RAM Replacement: step 12, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 12, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 12, image 3 of 3
      • Insert the RAM module at a 45-degree angle.
      • Make sure the module aligns with the slot. You can check by making sure the module pins' holes align with the slot.
      • With a finger on the top part of the module, push the RAM stick downward.
      • A click indicates that the module has been inserted successfully.
      Ask FixBot
    13. Lenovo Legion 5 17ACH6H RAM Replacement: step 13, image 1 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 13, image 2 of 3 Lenovo Legion 5 17ACH6H RAM Replacement: step 13, image 3 of 3
      • Repeat step 12 to insert the top RAM module.
      Ask FixBot
5 other people completed this guide.
Arturo Moreno
361 Reputation
1 Guide authored
CSU Los Angeles, Team 12-4, Ribeiro Fall 2023 Member of CSU Los Angeles, Team 12-4, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S12G4
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 61
Past 30 Days: 269
All Time: 6,509
