Lenovo Ideatab A1107 Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
103
All Time:
1,122
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
The Lenovo Ideatab A1107 Screen Replacement guide will show users how to safely remove the screen from the Lenovo Ideatab A1107. Included in the guide are the proper tools needed to complete the replacement, as well as photos with mark-ups.
Tools
    1. Lenovo Ideatab A1107 Screen Replacement, Back Cover: step 1, image 1 of 2 Lenovo Ideatab A1107 Screen Replacement, Back Cover: step 1, image 2 of 2
      • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
      • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
      Ask FixBot
    2. Lenovo Ideatab A1107 Screen Replacement: step 2, image 1 of 2 Lenovo Ideatab A1107 Screen Replacement: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
      Ask FixBot
    3. Lenovo Ideatab A1107 Screen Replacement: step 3, image 1 of 1
      • Lift up and remove the interior casing to expose the inner components.
      • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
      Ask FixBot
    1. Lenovo Ideatab A1107 Screen Replacement, Battery: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the tape covering the battery's wiring.
      Ask FixBot
    2. Lenovo Ideatab A1107 Screen Replacement: step 5, image 1 of 2 Lenovo Ideatab A1107 Screen Replacement: step 5, image 2 of 2
      • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
      • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
      • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
      Ask FixBot
    3. Lenovo Ideatab A1107 Screen Replacement: step 6, image 1 of 1
      • Wedge a plastic opening tool in between the battery and the internal components of the device.
      • Use the plastic opener tool to remove the battery from its casing.
      Ask FixBot
    1. Lenovo Ideatab A1107 Screen Replacement, Screen: step 7, image 1 of 1
      • Using you hands, lift off the digitizer.
      Ask FixBot
    2. Lenovo Ideatab A1107 Screen Replacement: step 8, image 1 of 2 Lenovo Ideatab A1107 Screen Replacement: step 8, image 2 of 2
      • Remove the three screws that are 2.0 mm in length and have a 5.25 mm head width with a Phillips #00 screwdriver.
      Ask FixBot
    3. Lenovo Ideatab A1107 Screen Replacement: step 9, image 1 of 2 Lenovo Ideatab A1107 Screen Replacement: step 9, image 2 of 2
      Buy
      • Use a spudger to remove the plastic piece securing the zero insertion force (ZIF) cable connector.
      • Use tweezers to grasp the ribbon cable, then pull the cable to disconnect it from the device.
      Ask FixBot
    4. Lenovo Ideatab A1107 Screen Replacement: step 10, image 1 of 1
      • Locate the black electrical tape strip on the side of the device.
      • Gently remove the tape from the device using the tweezers.
      Ask FixBot
    5. Lenovo Ideatab A1107 Screen Replacement: step 11, image 1 of 3 Lenovo Ideatab A1107 Screen Replacement: step 11, image 2 of 3 Lenovo Ideatab A1107 Screen Replacement: step 11, image 3 of 3
      • After removing the electric tape, gently lift up the green control panel.
      • Taking the tweezers, remove the ribbon cable from the control panel.
      • Once the ribbon cable is removed from the panel, the display should separate with ease.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 103
All Time: 1,122
