Lenovo Ideatab A1107 Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
97
All Time:
563
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
The Lenovo Ideatab A1107 Front Camera Replacement guide will show users how to safely remove the front camera component from the Lenovo Ideatab A1107. Included in the guide are the proper tools needed to complete the replacement, as well as photos with mark-ups.
Tools
    1. Lenovo Ideatab A1107 Front Camera Replacement, Back Cover: step 1, image 1 of 2 Lenovo Ideatab A1107 Front Camera Replacement, Back Cover: step 1, image 2 of 2
      • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
      • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
      Ask FixBot
    2. Lenovo Ideatab A1107 Front Camera Replacement: step 2, image 1 of 2 Lenovo Ideatab A1107 Front Camera Replacement: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
      Ask FixBot
    3. Lenovo Ideatab A1107 Front Camera Replacement: step 3, image 1 of 1
      • Lift up and remove the interior casing to expose the inner components.
      • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
      Ask FixBot
    1. Lenovo Ideatab A1107 Front Camera Replacement, Battery: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the tape covering the battery's wiring.
      Ask FixBot
    2. Lenovo Ideatab A1107 Front Camera Replacement: step 5, image 1 of 2 Lenovo Ideatab A1107 Front Camera Replacement: step 5, image 2 of 2
      • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
      • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
      • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
      Ask FixBot
    3. Lenovo Ideatab A1107 Front Camera Replacement: step 6, image 1 of 1
      • Wedge a plastic opening tool in between the battery and the internal components of the device.
      • Use the plastic opener tool to remove the battery from its casing.
      Ask FixBot
    1. Lenovo Ideatab A1107 Front Camera Replacement, Screen: step 7, image 1 of 1
      • Using you hands, lift off the digitizer.
      Ask FixBot
    2. Lenovo Ideatab A1107 Front Camera Replacement: step 8, image 1 of 2 Lenovo Ideatab A1107 Front Camera Replacement: step 8, image 2 of 2
      • Remove the three screws that are 2.0 mm in length and have a 5.25 mm head width with a Phillips #00 screwdriver.
      Ask FixBot
    3. Lenovo Ideatab A1107 Front Camera Replacement: step 9, image 1 of 2 Lenovo Ideatab A1107 Front Camera Replacement: step 9, image 2 of 2
      Buy
      • Use a spudger to remove the plastic piece securing the zero insertion force (ZIF) cable connector.
      • Use tweezers to grasp the ribbon cable, then pull the cable to disconnect it from the device.
      Ask FixBot
    4. Lenovo Ideatab A1107 Front Camera Replacement: step 10, image 1 of 1
      • Locate the black electrical tape strip on the side of the device.
      • Gently remove the tape from the device using the tweezers.
      Ask FixBot
    5. Lenovo Ideatab A1107 Front Camera Replacement: step 11, image 1 of 3 Lenovo Ideatab A1107 Front Camera Replacement: step 11, image 2 of 3 Lenovo Ideatab A1107 Front Camera Replacement: step 11, image 3 of 3
      • After removing the electric tape, gently lift up the green control panel.
      • Taking the tweezers, remove the ribbon cable from the control panel.
      • Once the ribbon cable is removed from the panel, the display should separate with ease.
      Ask FixBot
    1. Lenovo Ideatab A1107 Front Camera Replacement, Front Camera: step 12, image 1 of 2 Lenovo Ideatab A1107 Front Camera Replacement, Front Camera: step 12, image 2 of 2
      Buy
      • Using the tweezers, pull and remove the front camera component.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 97
All Time: 563
