Lenovo IdeaTab A2109 Camera Assembly Replacement
    1. Lenovo IdeaTab A2109 Camera Assembly Replacement, Camera Assembly: step 1, image 1 of 1
      • Look at the back of the tablet and locate the speakers on top of the rear cover.
      • Locate the small indentation in the plastic cover that runs across the top of the device.
      • Wedge the plastic opening tool in this indentation, under the middle of the cover as shown.
      • Pry up and push to remove the cover.
      Ask FixBot
    2. Lenovo IdeaTab A2109 Camera Assembly Replacement: step 2, image 1 of 2 Lenovo IdeaTab A2109 Camera Assembly Replacement: step 2, image 2 of 2
      • Remove the following two screws:
      • M3.0 x 3.0 mm #00 phillips screws (black)
      Ask FixBot
    3. Lenovo IdeaTab A2109 Camera Assembly Replacement: step 3, image 1 of 3 Lenovo IdeaTab A2109 Camera Assembly Replacement: step 3, image 2 of 3 Lenovo IdeaTab A2109 Camera Assembly Replacement: step 3, image 3 of 3
      • Pry open the front and rear faces using a plastic opening tool.
      • It may take a little force to separate the front and rear faces of the device.
      • Slide the plastic opening tool to one corner.
      • Place another plastic opening tool into the gap and slide it to the opposite corner as shown.
      • Pull the rear cover up and back to separate it from front face of the device.
      Ask FixBot
    4. Lenovo IdeaTab A2109 Camera Assembly Replacement: step 4, image 1 of 1
      • Slide the rear camera ribbon from the system board.
      • Pull up on the black plastic lock on the system board for the front camera and slide the ribbon out.
      • Now, you are ready to remove the front and rear facing cameras.
      Ask FixBot
Abigail Bertholf
521 Reputation
1 Guide authored
Cal Poly, Team 7-19, Regan Spring 2014 Member of Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 54
All Time: 1,016
