Lenovo IdeaPad Z570 Disc Drive Replacement
    1. Lenovo IdeaPad Z570 Disc Drive Replacement, Battery: step 1, image 1 of 1
      • Place the laptop face down with the battery facing away from you
      Ask FixBot
    2. Lenovo IdeaPad Z570 Disc Drive Replacement: step 2, image 1 of 1
      • Flip the right switch right-bound
      Ask FixBot
    3. Lenovo IdeaPad Z570 Disc Drive Replacement: step 3, image 1 of 1
      • Hold the left switch.
      Ask FixBot
    4. Lenovo IdeaPad Z570 Disc Drive Replacement: step 4, image 1 of 2 Lenovo IdeaPad Z570 Disc Drive Replacement: step 4, image 2 of 2
      • Push the battery forward lightly to remove it while holding the left switch.
      Ask FixBot
    1. Lenovo IdeaPad Z570 Disc Drive Replacement, Disc Drive: step 5, image 1 of 1
      • Place the laptop face down with the battery slot facing away from you.
      Ask FixBot
    2. Lenovo IdeaPad Z570 Disc Drive Replacement: step 6, image 1 of 2 Lenovo IdeaPad Z570 Disc Drive Replacement: step 6, image 2 of 2
      • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
      • These screws cannot be removed from the device.
      • Remove the back panel from the device.
      Ask FixBot
    3. Lenovo IdeaPad Z570 Disc Drive Replacement: step 7, image 1 of 2 Lenovo IdeaPad Z570 Disc Drive Replacement: step 7, image 2 of 2
      • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
      Ask FixBot
    4. Lenovo IdeaPad Z570 Disc Drive Replacement: step 8, image 1 of 2 Lenovo IdeaPad Z570 Disc Drive Replacement: step 8, image 2 of 2
      • Gently remove the disc drive from the left hand side of the laptop.
      Ask FixBot
Daniel Lopes
646 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,075
