Lenovo IdeaPad Yoga 11S Display Replacement
    1. Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: step 1, image 1 of 3 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: step 1, image 2 of 3 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: step 1, image 3 of 3
      • Remember to power off the device before removing any parts.
      • Position the laptop so that the bottom enclosure is facing upward.
      • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
      • Use an opening tool to carefully pry up the rubber pads.
      • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
      Ask FixBot
    2. Lenovo IdeaPad Yoga 11S Display Replacement, Remove Keyboard: step 2, image 1 of 1
      • Flip the laptop over and swing open the display.
      • Lift the edge of the keyboard closest to the trackpad up.
      • Carefully disconnect keyboard ribbon cable from the laptop.
      • Remove the keyboard.
      Ask FixBot
    3. Lenovo IdeaPad Yoga 11S Display Replacement: step 3, image 1 of 1
      • Remove the two screws securing the midframe.
      Ask FixBot
    4. Lenovo IdeaPad Yoga 11S Display Replacement: step 4, image 1 of 3 Lenovo IdeaPad Yoga 11S Display Replacement: step 4, image 2 of 3 Lenovo IdeaPad Yoga 11S Display Replacement: step 4, image 3 of 3
      • Grab the front edge of the top assembly and lift it up carefully.
      • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
      • Gently slide the three ribbon cables out of their slots.
      • Remove the top assembly completely by pulling it off of the device.
      Ask FixBot
    1. Lenovo IdeaPad Yoga 11S Display Replacement, Display: step 5, image 1 of 1
      • Keep the device positioned where it sits on the bottom encasing with the display open.
      • Locate the four 1.9mm screws used to attach the display brackets to the bottom enclosure of the device.
      • Use a Phillips #00 Screwdriver to remove the four screws.
      Ask FixBot
    2. Lenovo IdeaPad Yoga 11S Display Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to lift the retaining flap to disconnect the right display cable connector.
      • Gently pull the display cable out of the socket.
      Ask FixBot
    3. Lenovo IdeaPad Yoga 11S Display Replacement: step 7, image 1 of 1
      • Use a plastic opening tool to lift the retaining flap to disconnect the left display cable connector.
      Ask FixBot
    4. Lenovo IdeaPad Yoga 11S Display Replacement: step 8, image 1 of 1
      • Gently lift the display to detach it from the device.
      Ask FixBot
5 other people completed this guide.
Landon Epps
982 Reputation
5 Guides authored
Baylor, Team 7-11, Williams Spring 2015 Member of Baylor, Team 7-11, Williams Spring 2015
BU-WILLIAMS-S15S7G11
3 Members
59 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 33
All Time: 5,629
