Lenovo IdeaPad Y500 Fan Replacement
    1. Lenovo IdeaPad Y500 Fan Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement, Battery: step 1, image 3 of 3
      • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
      Ask FixBot
    2. Lenovo IdeaPad Y500 Fan Replacement: step 2, image 1 of 1
      • Unlike the first lock, this lock is spring loaded and must be held in place when used.
      • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
      Ask FixBot
    3. Lenovo IdeaPad Y500 Fan Replacement: step 3, image 1 of 1
      • Gently pull battery away from the computer while holding open the lock.
      Ask FixBot
    1. Lenovo IdeaPad Y500 Fan Replacement, Touchpad: step 4, image 1 of 2 Lenovo IdeaPad Y500 Fan Replacement, Touchpad: step 4, image 2 of 2
      • Remove a total of 8 screws.
      • Red circles are m2.5 x 10 mm flathead screws.
      • Orange circles m2 x 3mm flathead screws.
      • Yellow circle is m2.5 x 4mm flathead screw.
      Ask FixBot
    2. Lenovo IdeaPad Y500 Fan Replacement: step 5, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 5, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 5, image 3 of 3
      • Flip up black tabs at the ends of each cable.
      • With fingers, gently remove the cables underneath from their ports.
      Ask FixBot
    3. Lenovo IdeaPad Y500 Fan Replacement: step 6, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 6, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 6, image 3 of 3
      • By unlatching the sides and pulling up, remove the top case from the device.
      • Casing is fragile, be careful not to twist when pulling up.
      Ask FixBot
    1. Lenovo IdeaPad Y500 Fan Replacement, Keyboard: step 7, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement, Keyboard: step 7, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement, Keyboard: step 7, image 3 of 3
      • Unlock the battery latch by pulling it up.
      • It should reveal red underneath when it's unlocked.
      Ask FixBot
    2. Lenovo IdeaPad Y500 Fan Replacement: step 8, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 8, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 8, image 3 of 3
      • Push the latch down and then hold in position.
      • Pull the optical drive out.
      Ask FixBot
    3. Lenovo IdeaPad Y500 Fan Replacement: step 9, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 9, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 9, image 3 of 3
      • Remove nine screws with a Phillips #1 screwdriver.
      Ask FixBot
    4. Lenovo IdeaPad Y500 Fan Replacement: step 10, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 10, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 10, image 3 of 3
      • Pull up on the loosened cover to remove.
      • Remove two screws with a Phillips #1 screwdriver.
      Ask FixBot
    5. Lenovo IdeaPad Y500 Fan Replacement: step 11, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 11, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 11, image 3 of 3
      • Pull the tab straight to the left until part releases.
      • Lift up the part to remove completely.
      Ask FixBot
    6. Lenovo IdeaPad Y500 Fan Replacement: step 12, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 12, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 12, image 3 of 3
      • To release the DIMM, pull the tabs on either side away from each other simultaneously.
      • The DIMM will pop out on its own.
      Ask FixBot
    7. Lenovo IdeaPad Y500 Fan Replacement: step 13, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 13, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 13, image 3 of 3
      • To disconnect the Wi-Fi cables, use a spudger to gently push up under them.
      • Wi-Fi cables are delicate.
      Ask FixBot
    8. Lenovo IdeaPad Y500 Fan Replacement: step 14, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 14, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 14, image 3 of 3
      • Using a Phillips #1 screwdriver, remove the two screws.
      • Once screws are out, the card will just pop out.
      Ask FixBot
    9. Lenovo IdeaPad Y500 Fan Replacement: step 15, image 1 of 1
      • Remove three screws using a Phillips #1 screwdriver.
      Ask FixBot
    10. Lenovo IdeaPad Y500 Fan Replacement: step 16, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 16, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 16, image 3 of 3
      • With the laptop upside down, open slightly.
      • To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
      • You will not be able to pull the keyboard completely away. The cables are still connected to the laptop.
      Ask FixBot
    11. Lenovo IdeaPad Y500 Fan Replacement: step 17, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 17, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 17, image 3 of 3
      • To release the cables, use the spudger to push both ends on the side of the cable.
      • Gently pull the cables up to disconnect.
      Ask FixBot
    12. Lenovo IdeaPad Y500 Fan Replacement: step 18, image 1 of 2 Lenovo IdeaPad Y500 Fan Replacement: step 18, image 2 of 2
      • Pull the keyboard up and away from the laptop to remove it.
      Ask FixBot
    1. Lenovo IdeaPad Y500 Fan Replacement, Motherboard: step 19, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement, Motherboard: step 19, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement, Motherboard: step 19, image 3 of 3
      • Peel up the black tab and remove the tape completely.
      • Remove the cable revealed underneath while pulling up the tape.
      • When reassembled, you will have to stick the tape back down in its original location in order to reinsert the cable.
      Ask FixBot
    2. Lenovo IdeaPad Y500 Fan Replacement: step 20, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 20, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 20, image 3 of 3
      • Flip the laptop back over.
      • Gently pull the cable free by pulling up.
      Ask FixBot
    3. Lenovo IdeaPad Y500 Fan Replacement: step 21, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 21, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 21, image 3 of 3
      • Peel back the black tape.
      • Gently pull out both cables revealed underneath from their sockets.
      • When reassembling, you will have to paste the tape back over the cables again.
      Ask FixBot
    4. Lenovo IdeaPad Y500 Fan Replacement: step 22, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 22, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 22, image 3 of 3
      • By gently pulling up, remove the final cable.
      Ask FixBot
    5. Lenovo IdeaPad Y500 Fan Replacement: step 23, image 1 of 2 Lenovo IdeaPad Y500 Fan Replacement: step 23, image 2 of 2
      • Pull motherboard down, away from the case, while lifting the base of the case up.
      Ask FixBot
    1. Lenovo IdeaPad Y500 Fan Replacement, Fan: step 24, image 1 of 1
      • With a Phillips #1 screwdriver, loosen the six screws.
      • These screws are spring loaded. They will not come completely out. They only need to be loosened.
      Ask FixBot
    2. Lenovo IdeaPad Y500 Fan Replacement: step 25, image 1 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 25, image 2 of 3 Lenovo IdeaPad Y500 Fan Replacement: step 25, image 3 of 3
      • Gently lift the fan up to remove.
      Ask FixBot
Tatum Hennige
711 Reputation
4 Guides authored
UW Tacoma, Team S1-G2, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G2, Cardinal Spring 2019
UWT-CARDINAL-S19S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 76
All Time: 2,016
