Lenovo IdeaPad Y410p Keyboard Replacement
    1. Lenovo IdeaPad Y410p Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers are facing up.
      Ask FixBot
    2. Lenovo IdeaPad Y410p Keyboard Replacement: step 2, image 1 of 2 Lenovo IdeaPad Y410p Keyboard Replacement: step 2, image 2 of 2
      • Slide the left battery lock to the unlock position and release.
      • Slide the right battery lock to the unlock positon and hold it in place.
      Ask FixBot
    3. Lenovo IdeaPad Y410p Keyboard Replacement: step 3, image 1 of 2 Lenovo IdeaPad Y410p Keyboard Replacement: step 3, image 2 of 2
      • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
      Ask FixBot
    1. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: step 4, image 1 of 2 Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • Power off your laptop.
      • Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
      • After loosening the keyboard frame, you should be able to gently lift up the keyboard.
      Ask FixBot
    2. Lenovo IdeaPad Y410p Keyboard Replacement: step 5, image 1 of 3 Lenovo IdeaPad Y410p Keyboard Replacement: step 5, image 2 of 3 Lenovo IdeaPad Y410p Keyboard Replacement: step 5, image 3 of 3
      • Be careful when lifting the keyboard so that you do not damage the ribbon cable connector.
      • Detach the ribbon cables from the latches shown.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Terrible guide - completely fails to point out the two screws that hold the keyboard down underneath the bottom casing. Bent my keyboard thanks to this.
Dragon - Reply Share
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
Nateb - Reply Share
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 30
All Time: 1,450
