Lenovo IdeaPad U530 Touch RAM Replacement
    1. Lenovo IdeaPad U530 Touch RAM Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad U530 Touch RAM Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad U530 Touch RAM Replacement, Battery: step 1, image 3 of 3
      • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
      • Make sure to also remove the hinge screws.
      Ask FixBot
    2. Lenovo IdeaPad U530 Touch RAM Replacement: step 2, image 1 of 2 Lenovo IdeaPad U530 Touch RAM Replacement: step 2, image 2 of 2
      • To remove the panel, use a plastic opening tool to prevent any damage.
      Ask FixBot
    3. Lenovo IdeaPad U530 Touch RAM Replacement: step 3, image 1 of 1
      • Locate and assess the battery. Pictured in the upper right area of the computer.
      Ask FixBot
    4. Lenovo IdeaPad U530 Touch RAM Replacement: step 4, image 1 of 2 Lenovo IdeaPad U530 Touch RAM Replacement: step 4, image 2 of 2
      • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
      • Be careful to keep track of all removed screws.
      Ask FixBot
    5. Lenovo IdeaPad U530 Touch RAM Replacement: step 5, image 1 of 1
      • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
      • To remove the connection, please pull firmly, as it well secured.
      Ask FixBot
    6. Lenovo IdeaPad U530 Touch RAM Replacement: step 6, image 1 of 1
      • Simply lift the battery out of the computer, and acquire a replacement.
      Ask FixBot
    1. Lenovo IdeaPad U530 Touch RAM Replacement, RAM: step 7, image 1 of 2 Lenovo IdeaPad U530 Touch RAM Replacement, RAM: step 7, image 2 of 2
      • Carefully pull on the tabs on each side of the RAM to release it from its slot
      • Carefully pull the old RAM out of the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 680
