Lenovo IdeaPad U410 Solid State Drive Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
66
All Time:
1,192
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will take 5 minutes and will require you to follow a prerequisite guide on how to remove the back cover. The solid state replacement will require a Phillips #1 screwdriver and a metal spudger.
Parts
Tools
    1. Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: step 1, image 2 of 2
      • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
      Ask FixBot
    2. Lenovo IdeaPad U410 Solid State Drive  Replacement: step 2, image 1 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement: step 2, image 2 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement: step 2, image 3 of 3
      • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
      • Pry the panel from the laptop using your hands or the metal spudger if necessary.
      Ask FixBot
    1. Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: step 3, image 1 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: step 3, image 2 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: step 3, image 3 of 3
      • Make sure your laptop is powered off.
      • Use a Phillips #1 screwdriver to remove the 3 mm screw holding the SSD in place.
      Ask FixBot
    2. Lenovo IdeaPad U410 Solid State Drive  Replacement: step 4, image 1 of 1
      • Grab the SSD and pull it out from the mSATA slot.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 66
All Time: 1,192
