Lenovo IdeaPad U410 Screen Replacement
    1. Lenovo IdeaPad U410 Screen Replacement, Screen: step 1, image 1 of 2 Lenovo IdeaPad U410 Screen Replacement, Screen: step 1, image 2 of 2
      • Make sure your laptop is turned off before disassembling.
      • Power off the laptop.
      • Using the metal spudger, gently pry off the black trim around the screen.
      • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
      Ask FixBot
    2. Lenovo IdeaPad U410 Screen Replacement: step 2, image 1 of 2 Lenovo IdeaPad U410 Screen Replacement: step 2, image 2 of 2
      • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
      • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
      Ask FixBot
    3. Lenovo IdeaPad U410 Screen Replacement: step 3, image 1 of 3 Lenovo IdeaPad U410 Screen Replacement: step 3, image 2 of 3 Lenovo IdeaPad U410 Screen Replacement: step 3, image 3 of 3
      • Lower LCD screen onto the keyboard.
      • Find the gold connector on the bottom of the LCD panel.
      • Gently grab the connector on both sides and pull the connector straight out.
      • Connector cable is very fragile. Use the least amount of force possible.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 1,877
