Lenovo IdeaPad U350 Fan Replacement
  1. Lenovo IdeaPad U350 Fan Replacement, Battery: step 1, image 1 of 1
    • Locate the battery by turning the laptop over.
    Ask FixBot
  2. Lenovo IdeaPad U350 Fan Replacement: step 2, image 1 of 3 Lenovo IdeaPad U350 Fan Replacement: step 2, image 2 of 3 Lenovo IdeaPad U350 Fan Replacement: step 2, image 3 of 3
    • Locate the lock switch and slide toward the outside edge of the laptop until it clicks into place and the battery unit pops up.
    • Remove the battery unit from the laptop and set it aside.
    Ask FixBot
  3. Lenovo IdeaPad U350 Fan Replacement, Keyboard: step 3, image 1 of 1
    • Unscrew the three screws on the bottom of the laptop that have small keyboard logos next to them using a PH1 screwdriver. These screws are 5.8mm long.
    Ask FixBot
  4. Lenovo IdeaPad U350 Fan Replacement: step 4, image 1 of 2 Lenovo IdeaPad U350 Fan Replacement: step 4, image 2 of 2
    • Flip the computer over and open the screen.
    • Use a spudger to carefully press in the clip that is found here while prying the keyboard upward from the same side.
    • This clip is very stiff and also made of thin, brittle plastic. This means that it is easy to break off, which is what we did during our disassembly.
    Ask FixBot
  5. Lenovo IdeaPad U350 Fan Replacement: step 5, image 1 of 1
    • Slightly lift the bottom of the keyboard towards the screen to locate the keyboard's ribbon cable.
    • Use the tip of the spudger to lift the black retaining flap on the ZIF connector.
    • You should now be able to lift out the keyboard easily.
    Ask FixBot
  6. Lenovo IdeaPad U350 Fan Replacement, Hard Drive: step 6, image 1 of 1
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are attached to the panel. When unscrewing, be sure to stop when you here a click.
    Ask FixBot
  7. Lenovo IdeaPad U350 Fan Replacement: step 7, image 1 of 1
    • Lift the back panel from the side closest to the battery and remove the panel.
    Ask FixBot
  8. Lenovo IdeaPad U350 Fan Replacement: step 8, image 1 of 2 Lenovo IdeaPad U350 Fan Replacement: step 8, image 2 of 2
    • Slide the hard drive to the right, away from the RAM modules.
    • Lift the hard drive from the side closest to the RAM modules.
    • When re-inserting the hard drive, ensure that the copper contacts on the drive's connector are facing upwards.
    Ask FixBot
  9. Lenovo IdeaPad U350 Fan Replacement, Remove the screws: step 9, image 1 of 1
    • Unscrew the nine screws that are around the edge of the laptop using a PH00 screwdriver. These screws are 5.7mm long.
    • Unscrew the remaining two M2.5X3 screws that were under the battery using a PH1 screwdriver. These screws are 3.7mm long.
    • Unscrew the three M2X3 screws that were under the hard drive using a PH1 screwdriver. These screws are 3.7mm long.
    Ask FixBot
  10. Lenovo IdeaPad U350 Fan Replacement: step 10, image 1 of 3 Lenovo IdeaPad U350 Fan Replacement: step 10, image 2 of 3 Lenovo IdeaPad U350 Fan Replacement: step 10, image 3 of 3
    • Use the blue plastic opening tool to pry the silver plastic keyboard surround out from the black plastic bottom. You will need to do this around the entire perimeter of the laptop and will hear a pop every time one of the retention clips is unlatched.
    Ask FixBot
  11. Lenovo IdeaPad U350 Fan Replacement: step 11, image 1 of 1
    • Unscrew the two M2X3 screws that were under the keyboard.
    Ask FixBot
  12. Lenovo IdeaPad U350 Fan Replacement: step 12, image 1 of 2 Lenovo IdeaPad U350 Fan Replacement: step 12, image 2 of 2
    • Use the spudger to unlatch the retention clip on the power button and status LEDs ZIF connector.
    • This ribbon cable is glued to the case. Carefully pull up on it from the right side until it is no longer sticking to the case.
    Ask FixBot
  13. Lenovo IdeaPad U350 Fan Replacement: step 13, image 1 of 1
    • Use the spudger to unlatch the retention clip on the touchpad ZIF connector.
    • Lift the silver plastic keyboard surround away from the base of the laptop. There shouldn't be any resistance.
    Ask FixBot
  14. Lenovo IdeaPad U350 Fan Replacement: step 14, image 1 of 1
    • Unplug the fan wire from the motherboard.
    Ask FixBot
  15. Lenovo IdeaPad U350 Fan Replacement: step 15, image 1 of 1
    • Unscrew the three fan screws using a PH1 bit.
    • These screws are attached to the fan. When unscrewing, be sure to stop when you here a click.
    Ask FixBot
  16. Lenovo IdeaPad U350 Fan Replacement: step 16, image 1 of 3 Lenovo IdeaPad U350 Fan Replacement: step 16, image 2 of 3 Lenovo IdeaPad U350 Fan Replacement: step 16, image 3 of 3
    • Grip the fan from as far to the right (towards the center of the laptop) as possible and lift up.
    • As soon as the right side of the fan clears the bump in the case where the battery is housed, pull the fan to the right. This should dislodge it from the heatsink.
    Ask FixBot
2 other people completed this guide.
James Morizzo
499 Reputation
3 Guides authored
USF Tampa, Team 1-4, Hickman Fall 2014 Member of USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 36
All Time: 2,536
