Lenovo IdeaPad U310 Screen Replacement
    1. Lenovo IdeaPad U310 Screen  Replacement, Battery: step 1, image 1 of 1
      • Flip the device over so the bottom panel is facing up.
      • Remove the rubber feet by pinching and pulling in an upward motion.
      • The rubber feet are missing from this photo, but will be located within the red markups.
      Ask FixBot
    2. Lenovo IdeaPad U310 Screen  Replacement: step 2, image 1 of 1
      • Remove the 4 screws securing the bottom panel to the device.
      • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
      Ask FixBot
    3. Lenovo IdeaPad U310 Screen  Replacement: step 3, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 3, image 2 of 2
      • Place the plastic opening tool between the bottom panel and device.
      • Pry around the device's outer edge until the bottom panel is no longer attached.
      • Lift the bottom panel up and away from device.
      Ask FixBot
    4. Lenovo IdeaPad U310 Screen  Replacement: step 4, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 4, image 2 of 2
      • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
      Ask FixBot
    5. Lenovo IdeaPad U310 Screen  Replacement: step 5, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 5, image 2 of 2
      • Remove the 5.6 mm Screw with the PH1 screwdriver.
      • Remove the 4.6 mm screws with the PH1 screwdriver.
      Ask FixBot
    6. Lenovo IdeaPad U310 Screen  Replacement: step 6, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 6, image 2 of 2
      • Lift the strip tape away from the battery, being careful not to completely remove it.
      Ask FixBot
    7. Lenovo IdeaPad U310 Screen  Replacement: step 7, image 1 of 1
      • Remove the battery by lifting up and away from device.
      Ask FixBot
    1. Lenovo IdeaPad U310 Screen  Replacement, Screen: step 8, image 1 of 1
      • Insert opening tool between the frame and the back panel of the screen.
      Ask FixBot
    2. Lenovo IdeaPad U310 Screen  Replacement: step 9, image 1 of 1
      • Work your way around the frame until every connection is loose.
      Ask FixBot
    3. Lenovo IdeaPad U310 Screen  Replacement: step 10, image 1 of 1
      • Lift the screen up and away from the device.
      • Do not tamper with the tape on the bottom of the screen labeled "Don't touch".
      Ask FixBot
    4. Lenovo IdeaPad U310 Screen  Replacement: step 11, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 11, image 2 of 2
      • Remove the 1.9 mm screws using the PH0 screwdriver.
      • These screws are very short and small, keep track of them.
      Ask FixBot
    5. Lenovo IdeaPad U310 Screen  Replacement: step 12, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 12, image 2 of 2
      • Once the four screws are removed, gently rest the screen facedown on the keyboard.
      Ask FixBot
    6. Lenovo IdeaPad U310 Screen  Replacement: step 13, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 13, image 2 of 2
      • Peel back the white tape, revealing the power connection.
      Ask FixBot
    7. Lenovo IdeaPad U310 Screen  Replacement: step 14, image 1 of 2 Lenovo IdeaPad U310 Screen  Replacement: step 14, image 2 of 2
      • Unplug the connector, pulling it by the white tape.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 117
All Time: 5,666
