Lenovo IdeaPad U310 Battery Replacement
    1. Lenovo IdeaPad U310 Battery  Replacement, Battery: step 1, image 1 of 1
      • Flip the device over so the bottom panel is facing up.
      • Remove the rubber feet by pinching and pulling in an upward motion.
      • The rubber feet are missing from this photo, but will be located within the red markups.
      Ask FixBot
    2. Lenovo IdeaPad U310 Battery  Replacement: step 2, image 1 of 1
      • Remove the 4 screws securing the bottom panel to the device.
      • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
      Ask FixBot
    3. Lenovo IdeaPad U310 Battery  Replacement: step 3, image 1 of 2 Lenovo IdeaPad U310 Battery  Replacement: step 3, image 2 of 2
      • Place the plastic opening tool between the bottom panel and device.
      • Pry around the device's outer edge until the bottom panel is no longer attached.
      • Lift the bottom panel up and away from device.
      Ask FixBot
    4. Lenovo IdeaPad U310 Battery  Replacement: step 4, image 1 of 2 Lenovo IdeaPad U310 Battery  Replacement: step 4, image 2 of 2
      • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
      Ask FixBot
    5. Lenovo IdeaPad U310 Battery  Replacement: step 5, image 1 of 2 Lenovo IdeaPad U310 Battery  Replacement: step 5, image 2 of 2
      • Remove the 5.6 mm Screw with the PH1 screwdriver.
      • Remove the 4.6 mm screws with the PH1 screwdriver.
      Ask FixBot
    6. Lenovo IdeaPad U310 Battery  Replacement: step 6, image 1 of 2 Lenovo IdeaPad U310 Battery  Replacement: step 6, image 2 of 2
      • Lift the strip tape away from the battery, being careful not to completely remove it.
      Ask FixBot
    7. Lenovo IdeaPad U310 Battery  Replacement: step 7, image 1 of 1
      • Remove the battery by lifting up and away from device.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 37
Past 30 Days: 121
All Time: 6,100
