Lenovo IdeaPad S400 Touch RAM Replacement
    1. Lenovo IdeaPad S400 Touch RAM Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: step 1, image 3 of 3
      • Turn your computer over so the back is face up.
      • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
      • The battery cover will then pop up allowing you access to the battery.
      Ask FixBot
    1. Lenovo IdeaPad S400 Touch RAM Replacement, RAM: step 2, image 1 of 3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: step 2, image 2 of 3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: step 2, image 3 of 3
      • Remove the five 6mm Phillips #0 screws from the back panel.
      • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
      • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
      • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
      • Remove the three 6mm Phillips #0 screws from under the battery.
      Ask FixBot
    2. Lenovo IdeaPad S400 Touch RAM Replacement: step 3, image 1 of 1
      • Slide the back panel away to remove it.
      • Don't be afraid to apply force when removing the back panel.
      Ask FixBot
    3. Lenovo IdeaPad S400 Touch RAM Replacement: step 4, image 1 of 3 Lenovo IdeaPad S400 Touch RAM Replacement: step 4, image 2 of 3 Lenovo IdeaPad S400 Touch RAM Replacement: step 4, image 3 of 3
      • Push the metal arms away from the RAM.
      • The RAM should pop up.
      • Pull the RAM out.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 1,096
