Introduction
Go to step 1 ↓This guide will explain how to replace your System Memory (also known as RAM) for the Lenovo IdeaPad S210 Touch.
Faulty RAM modules may cause reduced system stability and performance. Replacing the RAM modules can not only increase system stability but provide performance you didnt have prior to the replacement.
Please take note that you will need DDR3 SDRAM modules to function with the laptop.
Tools
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
Release the RAM from the motherboard by pressing the two locking latches away from each other.
