Lenovo IdeaPad S10-2 Keyboard Replacement
    1. Lenovo IdeaPad S10-2 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Rotate the laptop so the back side is facing you.
      • From this side, you should be able to see both of the gaps where the two plastic materials meet.
      Ask FixBot
    2. Lenovo IdeaPad S10-2 Keyboard Replacement: step 2, image 1 of 2 Lenovo IdeaPad S10-2 Keyboard Replacement: step 2, image 2 of 2
      • Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
      Ask FixBot
    3. Lenovo IdeaPad S10-2 Keyboard Replacement: step 3, image 1 of 2 Lenovo IdeaPad S10-2 Keyboard Replacement: step 3, image 2 of 2
      • Open the laptop.
      • Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
      Ask FixBot
    4. Lenovo IdeaPad S10-2 Keyboard Replacement: step 4, image 1 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 4, image 2 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 4, image 3 of 3
      • Pull up on the loose component to remove.
      • As you lift the keyboard, you should be able to see a strip connected to the laptop.
      Ask FixBot
    5. Lenovo IdeaPad S10-2 Keyboard Replacement: step 5, image 1 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 5, image 2 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 5, image 3 of 3
      • Remove the strip by pulling both sides of the blue strip out.
      • Lift and remove the keyboard from the laptop.
      Ask FixBot
2 other people completed this guide.
Mary
132 Reputation
1 Guide authored
1 Guide Comment
Thanks! Just be careful when inserting the keyboard strips back into it's socket: that socket has retainer that needs to be released before inserting the strip. It is highlighted with different color, maybe brown. To release the strip pull the retainer in the same direction as when pulling out the keyboard strip, but do it before pulling that strip, so the strip will be released easily and can be inserted back when needed. Then push the retainer back...
Roman Vasylenko - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 3,567
