Lenovo IdeaPad G500 Replacing the Processor (CPU)
    1. Lenovo IdeaPad G500 Replacing the Processor (CPU), The Lock: step 1, image 1 of 1
      • First you have to release the "lock" for the battery. You can do this by simply pushing the two sliders in the direction of the arrows.
      • ATTENTION: The right slider does not lock, you have to hold it.
      Ask FixBot
    2. Lenovo IdeaPad G500 Replacing the Processor (CPU), Removal: step 2, image 1 of 1
      • Now you can pull the battery out and up. It might be a little tight, so feel free to use a little more force.
      Ask FixBot
    1. Lenovo IdeaPad G500 Replacing the Processor (CPU), The Screws: step 3, image 1 of 1
      • After the battery is removed, you can easily loosen the two screws shown using a Phillips screwdriver.
      • ATTENTION: Here is a guarantee seal! You have to break this to remove the back cover. Your warranty claims will therefore be lost! (Translator's note: This is not always true, check the law where you live.)
      Ask FixBot
    2. Lenovo IdeaPad G500 Replacing the Processor (CPU), Removing th Back Cover: step 4, image 1 of 1
      • Now you can easily slide off the back cover in the direction of the arrows.
      • You can then remove it by lifting upwards.
      Ask FixBot
    1. Lenovo IdeaPad G500 Replacing the Processor (CPU), The screws: step 5, image 1 of 1
      • As soon as you remove the back cover, you can see the fan and heatsink.
      • ATTENTION: When loosening the screws, make sure to loosen them carefully and evenly! (Not 'all-at-once', rather loosen each screw only a bit then do another one, then another to equalize pressure and avoid damaging underlying components... like the GPU)
      • Now remove the three screws marked in red with a Phillips screwdriver.
      • Some models have a dedicated graphics unit installed. If this is the case, the cooler is larger and the two screws marked in green also need to be removed (as in the ATTENTION! above!)
      Ask FixBot
    2. Lenovo IdeaPad G500 Replacing the Processor (CPU), Removal: step 6, image 1 of 1
      • Now, carefully remove the Heatsink/Fan assembly in the direction of the red arrow, be careful of the cooling fins, they are easily deformed.
      • Lift with a sideways motion toward the interior of the device to clear the radiating fins from the case.
      • Be careful not to damage the GPU.
      Ask FixBot
    1. Lenovo IdeaPad G500 Replacing the Processor (CPU), The Stop: step 7, image 1 of 2 Lenovo IdeaPad G500 Replacing the Processor (CPU), The Stop: step 7, image 2 of 2
      • The processor only fits into the socket in one direction! There is a small triangle on the processor, and also on the socket. (Image 2, pink circle)
      • Furthermore, the processor socket is locked with a slotted screw at the head of the socket! (Image 2, Yellow circle)
      • To remove the processor you must turn the screw marked in red 180 degrees. The pin should point to the opened lock.
      • You can then remove the processor.
      • When inserting the new one, pay attention to the small triangle on the processor!
      Ask FixBot
Reverse the steps to reassemble your device.
Special thanks to these translators:
de en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Daniel Kramp
1,308 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 105
All Time: 455
