Lenovo IdeaPad Flex-14IWL RAM Replacement
    1. Lenovo IdeaPad Flex-14IWL RAM Replacement, Lower Case: step 1, image 1 of 2 Lenovo IdeaPad Flex-14IWL RAM Replacement, Lower Case: step 1, image 2 of 2
      • Shut down the laptop completely.
      • Disconnect the charger and all external devices.
      • Flip the laptop over so the lower case is facing upward.
      • Make sure the device is completely powered off before continuing.
      Ask FixBot
    2. Lenovo IdeaPad Flex-14IWL RAM Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex-14IWL RAM Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the following screws securing the lower case:
      • Seven 2.5 mm-long
      • Three 5.5 mm-long
      Ask FixBot
    3. Lenovo IdeaPad Flex-14IWL RAM Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex-14IWL RAM Replacement: step 3, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide and pry with the pick around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Lenovo IdeaPad Flex-14IWL RAM Replacement, RAM: step 4, image 1 of 1
      • Use your fingernails to "walk" the battery connector directly out of its motherboard socket.
      • Locate the RAM module at the center of the motherboard.
      Ask FixBot
    2. Lenovo IdeaPad Flex-14IWL RAM Replacement: step 5, image 1 of 3 Lenovo IdeaPad Flex-14IWL RAM Replacement: step 5, image 2 of 3 Lenovo IdeaPad Flex-14IWL RAM Replacement: step 5, image 3 of 3
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Pull the RAM stick out of its socket at a 30° angle.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Debvarnini Mandal
469 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 26
All Time: 91
