Lenovo IdeaPad Flex 5-1470 RAM Replacement
    1. Lenovo IdeaPad Flex 5-1470 RAM Replacement, Back Panel: step 1, image 1 of 1
      • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    2. Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to lift up and remove the casing.
      Ask FixBot
    1. Lenovo IdeaPad Flex 5-1470 RAM Replacement, RAM: step 3, image 1 of 1
      • Use a spudger to gently bend down the locking tabs on the RAM casing.
      Ask FixBot
    2. Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 4, image 1 of 1
      • Use a spudger to gently lift the RAM casing, then lift it up and off.
      Ask FixBot
    3. Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 5-1470 RAM Replacement: step 5, image 2 of 2
      • Gently take hold of the RAM card and lift slightly.
      • Pull the RAM card directly out of its port.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 77
All Time: 2,034
