Lenovo IdeaPad 530S-14IKB Screen Assembly Replacement
    1. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Remove the bottom cover: step 1, image 1 of 2 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Remove the bottom cover: step 1, image 2 of 2
      • Unscrew all 10 T5 screws. The screws are all the same length.
      • Remove the bottom cover carefully. Maybe it is necessary to use a pick or spudger.
      Ask FixBot
    2. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the battery: step 2, image 1 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the battery: step 2, image 2 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the battery: step 2, image 3 of 3
      • Disconnect the battery off the main board.
      Ask FixBot
    3. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the antenna cables and mainboard: step 3, image 1 of 2 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the antenna cables and mainboard: step 3, image 2 of 2
      • Disconnect antenna cable 1 and 2 und pull them out of their holding.
      Ask FixBot
    4. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the display and mainboard: step 4, image 1 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the display and mainboard: step 4, image 2 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the display and mainboard: step 4, image 3 of 3
      • Open the black lever on the display connection and carefully pull out the ribbon cable parallel to the mainboard. Do NOT pull upwards!
      Ask FixBot
    5. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Separate the display assembly: step 5, image 1 of 1
      • Open the laptop in a 90 degree angle. Unscrew the 4 PH0 screws (all the same length).
      • Carefully separate the display and chassis. Take special care with the antenna cables and display ribbon cable.
      Ask FixBot
    6. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Separate the covers on the display: step 6, image 1 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Separate the covers on the display: step 6, image 2 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Separate the covers on the display: step 6, image 3 of 3
      • Move the plastic cover from left to right. This might take a little bit of force.
      • It clicks and is easily removed afterwards.
      • The coverstrip underneath can be removed with a spudger.
      Ask FixBot
    7. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Separate the display assembly of the enclosure: step 7, image 1 of 2 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Separate the display assembly of the enclosure: step 7, image 2 of 2
      • Unscrew the highlighted two PH000 screws (same length).
      • Pull out the pull tabs from underneath the display assembly. Take your time and pull very carefully and even.
      • ATTENTION: Always grasp the pull tab as near to the display as possible. Like this you avoid tearing it.
      Ask FixBot
    8. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Lift the display assembly from the enclosure: step 8, image 1 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Lift the display assembly from the enclosure: step 8, image 2 of 3 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Lift the display assembly from the enclosure: step 8, image 3 of 3
      • Carfully push down on the display while pushing it in the direction of the arrows.
      • Lift up the display assembly just a few millimeters and then push it further in the direction oft the arrows to unclick the display assembly from the enclosure. Finally you can without force lift up the display in a 90 degree angle.
      Ask FixBot
    9. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the display assembly and enclosure: step 9, image 1 of 2 Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Disconnect the display assembly and enclosure: step 9, image 2 of 2
      • Disconnect the 30 pole ribbon cable of the display assembly. To do that you have to open the connection with the small metal lever. After opening it you can pull the ribbon cable straight down.
      Ask FixBot
    10. Lenovo IdeaPad 530S-14IKB  Screen Assembly Replacement, Put in the new display assembly: step 10, image 1 of 1
      • Apply the new pull tabs so that you can easily replace the screen again.
      • To reassemble your device, follow these instructions in reverse order.
      Ask FixBot
2 other people completed this guide.
Special thanks to these translators:
de en
100%
Leonard Pitt Diehl is helping us fix the world! Want to contribute?
Start translating ›
Leonard Pitt Diehl
361 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 84
All Time: 5,508
