Lenovo IdeaPad 300-17ISK RAM Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
102
All Time:
3,332
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
You may find yourself in need of additional memory to feed hungry computer applications such as graphics and video editing tools. If you would like to replace a faulty RAM stick or one with insufficient capacity, follow this guide.
The battery for this device is not easily accessible and cannot be easily removed. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you drain the battery completely before you begin this replacement.
Parts
Tools
    1. Lenovo IdeaPad 300-17ISK RAM Replacement, Bottom Back Cover: step 1, image 1 of 1
      • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
      Ask FixBot
    2. Lenovo IdeaPad 300-17ISK RAM Replacement: step 2, image 1 of 2 Lenovo IdeaPad 300-17ISK RAM Replacement: step 2, image 2 of 2
      • Place your hands at the bottom of the cover and slide it towards you.
      • Lift the cover up to remove it.
      Ask FixBot
    1. Lenovo IdeaPad 300-17ISK RAM Replacement, RAM: step 3, image 1 of 1
      • The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
      Ask FixBot
    2. Lenovo IdeaPad 300-17ISK RAM Replacement: step 4, image 1 of 3 Lenovo IdeaPad 300-17ISK RAM Replacement: step 4, image 2 of 3 Lenovo IdeaPad 300-17ISK RAM Replacement: step 4, image 3 of 3
      • Locate the two dislocating latches on each side of the stick and place your fingers on them.
      • Pull the tabs away from the stick simultaneously until the stick pops out of place.
      • Gently remove the RAM stick once it has popped out of its place.
      • If necessary, repeat the same process with the second RAM stick that is adjacent to the first one.
      Ask FixBot
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Ammar Dodin
1,057 Reputation
6 Guides authored
UC Davis, Team 1-3, Rodger Winter 2017 Member of UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 102
All Time: 3,332
