Lenovo IdeaPad 300-17ISK Optical Drive Replacement
    1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: step 1, image 1 of 1
      • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
      Ask FixBot
    2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 2, image 1 of 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 2, image 2 of 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 2, image 3 of 3
      • Place the opening tool's head under any edge of the keyboard.
      • Pull upwards to unsnap the keyboard.
      • Use your fingers and the opening tool to pop the keyboard out of its place.
      • You should't use any excessive force because the keyboard is still attached to the motherboard.
      Ask FixBot
    3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 3, image 1 of 2 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 3, image 2 of 2
      • Push the keyboard connector latch upwards with the spudger.
      • You shouldn't use excessive force. The connector latch is very fragile.
      • The keyboard connector cable should slide right out.
      Ask FixBot
    1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: step 4, image 1 of 1
      • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
      Ask FixBot
    2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 5, image 1 of 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 5, image 2 of 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: step 5, image 3 of 3
      • Insert the opening tool's head into one of the tabbed holes.
      • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
      Ask FixBot
Ammar Dodin
1,057 Reputation
6 Guides authored
UC Davis, Team 1-3, Rodger Winter 2017 Member of UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 5,796
