Introduction
This guide will walk you through the process of replacing the fan in your Lenovo IdeaPad 3-15IML05. Over time, dust or a faulty fan can lead to overheating and system issues. By following these steps, you'll be able to replace the fan y and restore optimal cooling performance to your laptop.
Before you begin this repair, make sure that your laptop is off and disconnected from the power adapter.
Use a Phillips #1 screwdriver to remove the following screws:
Six 7 mm screws
Four 4 mm screws
Use a plastic spudger or your fingernail to gently push the JST battery connector out of its socket.
Use a Phillips screwdriver to remove the three screws securing the fan to the chassis.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
