Lenovo IdeaPad 3-15IIL05 RAM Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
11
Past 7 Days:
70
Past 30 Days:
191
All Time:
5,127
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace or upgrade the RAM (aka memory module) in your Lenovo IdeaPad 3-15IIL05 laptop.
Note: This laptop has one slot for SO-DIMM, DDR4 memory.
Parts
Tools
    1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Unfasten the back cover: step 2, image 1 of 2 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Unfasten the back cover: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the ten screws securing the back cover:
      • Six 7.6 mm-long screws
      • Four 4.7 mm-long screws
      Ask FixBot
    2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: step 3, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: step 3, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: step 3, image 3 of 3
      • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
      • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
      • Angle the pick down to about 45 degrees.
      Ask FixBot
    3. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: step 4, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: step 4, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: step 4, image 3 of 3
      • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
      • Slide the pick to the bottom left corner of the laptop to release the left clips.
      Ask FixBot
    4. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: step 5, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: step 5, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: step 5, image 3 of 3
      • Slide the opening pick to the bottom right corner to release the bottom clips.
      Ask FixBot
    5. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: step 6, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: step 6, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: step 6, image 3 of 3
      • Slide the opening pick to the top right corner to release the right clips.
      Ask FixBot
    6. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: step 7, image 1 of 2 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: step 7, image 2 of 2
      • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
      • Pry the back cover up with the pick to release the top right clips.
      • Leave the pick inserted next to the right hinge.
      Ask FixBot
    7. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: step 8, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: step 8, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: step 8, image 3 of 3
      • Angle the pick up to about 45 degrees.
      • Slide the opening pick to the top left corner to release the remaining clips.
      Ask FixBot
    8. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: step 9, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: step 9, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: step 9, image 3 of 3
      • Remove the back cover.
      • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
      Ask FixBot
    1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: step 10, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: step 10, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: step 10, image 3 of 3
      • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
      Ask FixBot
    1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: step 11, image 1 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: step 11, image 2 of 3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: step 11, image 3 of 3
      • Two metal arms secure the stick of RAM.
      • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
      • Remove the stick of RAM.
      • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
      Ask FixBot
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
206,618 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
4 Guide Comments
how much ram is supported in this model i would like to know
Mahfujul Islam Bhuiyan - Reply Share
Hi! This laptop has one slot for DDR4 SO-DIMM memory and supports up to 20GB.
Spencer Day - Reply Share
It supports 20gb any reason to go over that? Just wondering because I saw compuram.de saying there is and I got no clue lol explain it like I’m 5
Robert - Reply Share
I'm seeing options for going up to 32 gb and even 64 gb of RAM in my Lenovo ideapad 3 15iil05, is this actually a good idea to go foward with this if I'm doing video editing and college work on the same device?
theron - Reply Share
Past 24 Hours: 11
Past 7 Days: 70
Past 30 Days: 191
All Time: 5,127
