Lenovo IdeaPad 3-15ADA05 RAM Replacement
    1. Lenovo IdeaPad 3-15ADA05 RAM Replacement, RAM: step 1, image 1 of 2 Lenovo IdeaPad 3-15ADA05 RAM Replacement, RAM: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the six M2 x 5 mm screws located at the top half of the laptop.
      • Use a Phillips #0 screwdriver to remove the four M2 x 2.5 mm screws located at the bottom of the laptop.
      Ask FixBot
    2. Lenovo IdeaPad 3-15ADA05 RAM Replacement: step 2, image 1 of 2 Lenovo IdeaPad 3-15ADA05 RAM Replacement: step 2, image 2 of 2
      • Insert the pry pick between the base plate and the bottom of the laptop, and pry the clips loose around the edge until the base pops off.
      Ask FixBot
    3. Lenovo IdeaPad 3-15ADA05 RAM Replacement: step 3, image 1 of 2 Lenovo IdeaPad 3-15ADA05 RAM Replacement: step 3, image 2 of 2
      • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
      • The RAM will pop up at a slight angle.
      Ask FixBot
    4. Lenovo IdeaPad 3-15ADA05 RAM Replacement: step 4, image 1 of 2 Lenovo IdeaPad 3-15ADA05 RAM Replacement: step 4, image 2 of 2
      • Slide the RAM stick out of the motherboard slot.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 73
All Time: 972
