Lenovo IdeaPad 3-15ADA05 Display Replacement
    1. Lenovo IdeaPad 3-15ADA05 Display Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad 3-15ADA05 Display Replacement, Back Panel: step 1, image 2 of 2
      • Remove the six 5 mm screws located at the top half of the laptop using a Phillips #0 screwdriver.
      • Remove the four 2.5 mm screws located at the bottom of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Lenovo IdeaPad 3-15ADA05 Display Replacement: step 2, image 1 of 2 Lenovo IdeaPad 3-15ADA05 Display Replacement: step 2, image 2 of 2
      • Insert the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
      Ask FixBot
    1. Lenovo IdeaPad 3-15ADA05 Display Replacement, Battery: step 3, image 1 of 2 Lenovo IdeaPad 3-15ADA05 Display Replacement, Battery: step 3, image 2 of 2
      • Using a #0 Phillips head, remove the five M2 x 3.5mm screws holding the battery in place.
      Ask FixBot
    2. Lenovo IdeaPad 3-15ADA05 Display Replacement: step 4, image 1 of 2 Lenovo IdeaPad 3-15ADA05 Display Replacement: step 4, image 2 of 2
      • Using the opening tool, disconnect the battery connector from the motherboard, and then remove the battery.
      Ask FixBot
    1. Lenovo IdeaPad 3-15ADA05 Display Replacement, Display: step 5, image 1 of 2 Lenovo IdeaPad 3-15ADA05 Display Replacement, Display: step 5, image 2 of 2
      • Disconnect the black and white antenna cables from the wireless card using the opening tool.
      • Unwrap the cord from the three clips.
      • To remove the cords, push them through the small gaps.
      Ask FixBot
    2. Lenovo IdeaPad 3-15ADA05 Display Replacement: step 6, image 1 of 3 Lenovo IdeaPad 3-15ADA05 Display Replacement: step 6, image 2 of 3 Lenovo IdeaPad 3-15ADA05 Display Replacement: step 6, image 3 of 3
      • Remove the four 7 mm screws from both hinges using a Phillips #0 screwdriver.
      Ask FixBot
    3. Lenovo IdeaPad 3-15ADA05 Display Replacement: step 7, image 1 of 2 Lenovo IdeaPad 3-15ADA05 Display Replacement: step 7, image 2 of 2
      • Using iFixit precision tweezers, remove the LCD cable from its slot.
      Ask FixBot
    4. Lenovo IdeaPad 3-15ADA05 Display Replacement: step 8, image 1 of 1
      • Carefully separate the display from the keyboard.
      Ask FixBot
Vy Nguyen
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 88
All Time: 905
