Lenovo IdeaPad 3-14IIL05 RAM Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
112
All Time:
853
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to replace the RAM in your Lenovo IdeaPad 3-14IIL05.
The RAM is the memory of the computer. If your computer is running slow, look in your task manager and observe to see if the RAM is the issue. If it is, consider upgrading.
Tools
    1. Lenovo IdeaPad 3-14IIL05 RAM Replacement, Back Panel: step 1, image 1 of 3 Lenovo IdeaPad 3-14IIL05 RAM Replacement, Back Panel: step 1, image 2 of 3 Lenovo IdeaPad 3-14IIL05 RAM Replacement, Back Panel: step 1, image 3 of 3
      • Flip the laptop with the screen side facing down and the back panel facing you.
      • Remove the six 1.2 mm screws and the four 0.6 mm screws using a Phillips #1 screwdriver.
      • Make sure to separate the different sizes from each other.
      Ask FixBot
    1. Lenovo IdeaPad 3-14IIL05 RAM Replacement, RAM: step 2, image 1 of 3 Lenovo IdeaPad 3-14IIL05 RAM Replacement, RAM: step 2, image 2 of 3 Lenovo IdeaPad 3-14IIL05 RAM Replacement, RAM: step 2, image 3 of 3
      • Hold the two clips on either end of the short side of the RAM and push them apart.
      • The RAM will pop up.
      • Remove the RAM.
      Ask FixBot
Emily Hesketh
357 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Konn Fall 2024 Member of UMass Dartmouth, Team 1-3, Konn Fall 2024
UMASSD-KONN-F24S1G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 112
All Time: 853
