Lenovo IdeaPad 110-15ISK RAM Replacement
    1. Lenovo IdeaPad 110-15ISK RAM Replacement, Keyboard: step 1, image 1 of 1
      • Flip the IdeaPad bottom side up.
      • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
      • Flip the computer back to top facing.
      Ask FixBot
    2. Lenovo IdeaPad 110-15ISK RAM Replacement: step 2, image 1 of 1
      • Open the lid.
      • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
      Ask FixBot
    3. Lenovo IdeaPad 110-15ISK RAM Replacement: step 3, image 1 of 1
      • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
      • Completely remove the keyboard from the bottom assembly.
      Ask FixBot
      • Unlock the ZIF conector before pulling the cable out
      Ask FixBot
    1. Lenovo IdeaPad 110-15ISK RAM Replacement, Optical Drive: step 5, image 1 of 1
      • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
      Ask FixBot
    2. Lenovo IdeaPad 110-15ISK RAM Replacement: step 6, image 1 of 1
      • Flip the laptop to its back and the optical drive is located at the top left corner.
      • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
      Ask FixBot
    1. Lenovo IdeaPad 110-15ISK RAM Replacement, Upper Case: step 7, image 1 of 1
      • Place the laptop bottom facing up.
      • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
      Ask FixBot
    2. Lenovo IdeaPad 110-15ISK RAM Replacement: step 8, image 1 of 1
      • Separate the top case from the bottom using a plastic opening tool.
      • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
      Ask FixBot
    1. Lenovo IdeaPad 110-15ISK RAM Replacement, Battery: step 9, image 1 of 1
      • Turn the laptop upside down and gently pry the top case free from the bottom case.
      Ask FixBot
    2. Lenovo IdeaPad 110-15ISK RAM Replacement: step 10, image 1 of 1
      • The battery is attached to the bottom case of the laptop.
      • Remove the two 4.0mm screws.
      • Push the battery component away from you in order to completely remove the battery from the fixture.
      Ask FixBot
    1. Lenovo IdeaPad 110-15ISK RAM Replacement, RAM: step 11, image 1 of 1
      • On the back panel, the RAM is located at the bottom of the logic board.
      • Press the silver two hinges at the bottom corners of the RAM to loosen the RAM.
      • Remove the loosened RAM from the back panel.
      Ask FixBot
7 other people completed this guide.
Jakub Szark
550 Reputation
5 Guides authored
UW Tacoma, Team S1-G5, Rose Fall 2018 Member of UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 130
All Time: 15,366
