Introduction
Go to step 1 ↓This guide will show you have to replace the ram in your Lenovo IdeaPad 1-15ALC7.
Tools
Unscrew and remove the T5 Torx screws that secure the lower case:
Six 6.5 mm screws
Four 5 mm screws
Insert a Jimmy into the seam between the lower case and chassis.
Pry around the entire perimeter until the lower case fully releases.
Remove the lower case.
Use tweezers or your fingernails to gently "walk" the battery connector directly out of its motherboard socket.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Remove the module from the slot.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
