Lenovo IdeaCentre K410 RAM Module Replacement
    1. Lenovo IdeaCentre K410 RAM Module Replacement, Side Panel: step 1, image 1 of 1
      • Lay the computer down on its side as shown.
      • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
      Ask FixBot
    2. Lenovo IdeaCentre K410 RAM Module Replacement: step 2, image 1 of 1
      • Gently slide the side panel straight back and remove from the computer.
      Ask FixBot
    1. Lenovo IdeaCentre K410 RAM Module Replacement, RAM Module: step 3, image 1 of 1
      • Push down on the white clips on both sides of the memory module to release it.
      • Gently pull up on the memory module to remove it from the unit.
      Ask FixBot
When inserting the memory module, make sure that the notch on it aligns correctly with the key on the memory connector. Push the module straight down into the connector until the retaining clips close.
2 other people completed this guide.
Timothy Grebe
1,652 Reputation
9 Guides authored
Cal Poly, Team 10-39, Amido Fall 2014 Member of Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Members
108 Guides authored
2 Guide Comments
sounds very hard to replace a ram “sarcastically“
you probley can replace a ram if you know what ram is so
remliv - Reply Share
But it is still good to have guides on everything
im glad that ifixit exists
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,026
