Lenovo G780 Screen Replacement
    1. Lenovo G780 Screen Replacement, Battery: step 1, image 1 of 2 Lenovo G780 Screen Replacement, Battery: step 1, image 2 of 2
      • Turn off the computer.
      • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
      Ask FixBot
    2. Lenovo G780 Screen Replacement: step 2, image 1 of 1
      • Hold the battery release switch in the unlocked position and remove the battery.
      Ask FixBot
    1. Lenovo G780 Screen Replacement, Screen: step 3, image 1 of 2 Lenovo G780 Screen Replacement, Screen: step 3, image 2 of 2
      • Using the metal spudger, peel back the adhesive-backed bumpers on the bottom left and right corners of the screen.
      Ask FixBot
    2. Lenovo G780 Screen Replacement: step 4, image 1 of 3 Lenovo G780 Screen Replacement: step 4, image 2 of 3 Lenovo G780 Screen Replacement: step 4, image 3 of 3
      • Using a Phillips #1 screwdriver, remove both 5.5mm screws from the corners of the screen.
      Ask FixBot
    3. Lenovo G780 Screen Replacement: step 5, image 1 of 3 Lenovo G780 Screen Replacement: step 5, image 2 of 3 Lenovo G780 Screen Replacement: step 5, image 3 of 3
      • Using an iFixit opening tool, start prying on the top face cover on the screen by applying pressure near the bottom of the screen.
      • Once the face cover has started to come away from the screen, begin pulling away with both hands until the whole face cover has been removed from the screen.
      • Be careful not to break the thin plastic cover.
      Ask FixBot
    4. Lenovo G780 Screen Replacement: step 6, image 1 of 3 Lenovo G780 Screen Replacement: step 6, image 2 of 3 Lenovo G780 Screen Replacement: step 6, image 3 of 3
      • Remove the four 8.5mm screws on the corners of the screen that connect the screen frame to the back cover.
      Ask FixBot
    5. Lenovo G780 Screen Replacement: step 7, image 1 of 2 Lenovo G780 Screen Replacement: step 7, image 2 of 2
      • With the back cover being removed from the screen frame, the back cover can be set aside.
      Ask FixBot
    6. Lenovo G780 Screen Replacement: step 8, image 1 of 3 Lenovo G780 Screen Replacement: step 8, image 2 of 3 Lenovo G780 Screen Replacement: step 8, image 3 of 3
      • Carefully remove the clear adhesive tape holding the cable down, being careful not to damage the small wires under the tape.
      • Once the tape has been removed, the ribbon connector will pull away from the back of screen.
      Ask FixBot
    7. Lenovo G780 Screen Replacement: step 9, image 1 of 3 Lenovo G780 Screen Replacement: step 9, image 2 of 3 Lenovo G780 Screen Replacement: step 9, image 3 of 3
      • Remove the eight, 3mm screws around the screen frame. There will be four on each side of the screen frame.
      • With the screws removed the screen will be free to be lifted away from the screen frame.
      Ask FixBot
2 other people completed this guide.
Riley Griffin
316 Reputation
3 Guides authored
IUPUI, Team S2-G4, Henning Spring 2019 Member of IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 85
All Time: 1,574
