Lenovo G70-80 Screen Replacement
    1. Lenovo G70-80 Screen Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Set the computer upside down with the back facing up.
      Ask FixBot
    2. Lenovo G70-80 Screen Replacement: step 2, image 1 of 2 Lenovo G70-80 Screen Replacement: step 2, image 2 of 2
      • Located directly below the bottom plate will be two switches near where the battery is located.
      • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
      • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
      Ask FixBot
    3. Lenovo G70-80 Screen Replacement: step 3, image 1 of 2 Lenovo G70-80 Screen Replacement: step 3, image 2 of 2
      • Slide the left battery release switch to the left.
      • While holding the switch to the left, lift the battery to remove it from the computer.
      Ask FixBot
    4. Lenovo G70-80 Screen Replacement: step 4, image 1 of 2 Lenovo G70-80 Screen Replacement: step 4, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. Lenovo G70-80 Screen Replacement, Screen: step 5, image 1 of 1
      • Open the laptop to face the screen.
      Ask FixBot
    2. Lenovo G70-80 Screen Replacement: step 6, image 1 of 3 Lenovo G70-80 Screen Replacement: step 6, image 2 of 3 Lenovo G70-80 Screen Replacement: step 6, image 3 of 3
      • Use a plastic opening tool to pull the bezel forward and release it from the top of the LCD panel.
      • The bezel is the plastic frame around the laptop screen.
      Ask FixBot
    3. Lenovo G70-80 Screen Replacement: step 7, image 1 of 2 Lenovo G70-80 Screen Replacement: step 7, image 2 of 2
      • After the top part of the bezel is released, use the plastic opening tool to completely remove the bezel.
      • If you are having trouble removing the bezel from the LCD panel, pull both sides of the bezel towards you with your hands.
      Ask FixBot
    4. Lenovo G70-80 Screen Replacement: step 8, image 1 of 3 Lenovo G70-80 Screen Replacement: step 8, image 2 of 3 Lenovo G70-80 Screen Replacement: step 8, image 3 of 3
      • Use a screwdriver to remove the screws that secure the LCD panel to the computer.
      • Once the bezel is removed, you will see eight screws around the screen that secure the LCD panel to the computer.
      Ask FixBot
    5. Lenovo G70-80 Screen Replacement: step 9, image 1 of 1
      • Carefully separate the LCD panel from the plastic cover, placing it face down on the keyboard
      Ask FixBot
    6. Lenovo G70-80 Screen Replacement: step 10, image 1 of 1
      • Disconnect the LCD panel from the computer by peeling the connector off.
      Ask FixBot
    7. Lenovo G70-80 Screen Replacement: step 11, image 1 of 2 Lenovo G70-80 Screen Replacement: step 11, image 2 of 2
      • With a screwdriver, remove the four screws that mount the LCD panel onto the mounting arms.
      • There is one screw on each corner that connects to the mounting arms.
      Ask FixBot
    8. Lenovo G70-80 Screen Replacement: step 12, image 1 of 1
      • Remove the LCD panel.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
how do you repair a whitescreen effect for a lenovo110 ideapad
sidney ifedha - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 94
All Time: 2,238
