Up to 20% off select tools
Lenovo G70-80 RAM Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
98
All Time:
1,897
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 6 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Outline what you are going to teach someone how to do.
    1. Lenovo G70-80 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Set the computer upside down with the back facing up.
      Ask FixBot
    2. Lenovo G70-80 RAM Replacement: step 2, image 1 of 2 Lenovo G70-80 RAM Replacement: step 2, image 2 of 2
      • Located directly below the bottom plate will be two switches near where the battery is located.
      • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
      • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
      Ask FixBot
    3. Lenovo G70-80 RAM Replacement: step 3, image 1 of 2 Lenovo G70-80 RAM Replacement: step 3, image 2 of 2
      • Slide the left battery release switch to the left.
      • While holding the switch to the left, lift the battery to remove it from the computer.
      Ask FixBot
    4. Lenovo G70-80 RAM Replacement: step 4, image 1 of 2 Lenovo G70-80 RAM Replacement: step 4, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. Lenovo G70-80 RAM Replacement, RAM: step 5, image 1 of 3 Lenovo G70-80 RAM Replacement, RAM: step 5, image 2 of 3 Lenovo G70-80 RAM Replacement, RAM: step 5, image 3 of 3
      • Remove the placeholder screws and pull off the backplate.
      Ask FixBot
    2. Lenovo G70-80 RAM Replacement: step 6, image 1 of 3 Lenovo G70-80 RAM Replacement: step 6, image 2 of 3 Lenovo G70-80 RAM Replacement: step 6, image 3 of 3
      • Carefully pull the two metal retaining clips away from the sides of the RAM module.
      • As the clips release, the RAM module should pop up at an angle.
      • Remove the RAM from the device.
      Ask FixBot
Author
with
Alexis Buford
677 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 98
All Time: 1,897
