Lenovo G70-70 Keyboard Replacement
    1. Lenovo G70-70 Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo G70-70 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Ensure the battery is removed before attempting to fix anything on the laptop.
      • Orient the laptop so the bottom side is facing you.
      • To unlock the battery, place your thumb over the left switch and slide it to the left.
      Ask FixBot
    2. Lenovo G70-70 Keyboard Replacement: step 2, image 1 of 2 Lenovo G70-70 Keyboard Replacement: step 2, image 2 of 2
      • To access the battery, place your thumb over the right switch and slide it to the right.
      • When the battery is unlocked, it will automatically pop up.
      Ask FixBot
    3. Lenovo G70-70 Keyboard Replacement: step 3, image 1 of 3 Lenovo G70-70 Keyboard Replacement: step 3, image 2 of 3 Lenovo G70-70 Keyboard Replacement: step 3, image 3 of 3
      • Remove the battery by lifting it up and away from yourself.
      Ask FixBot
    1. Lenovo G70-70 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Lenovo G70-70 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Lenovo G70-70 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • Turn your laptop so the bottom side is facing you.
      • Remove two 7.3 mm Phillips #0 screws.
      • Slide the back cover towards yourself.
      Ask FixBot
    2. Lenovo G70-70 Keyboard Replacement: step 5, image 1 of 3 Lenovo G70-70 Keyboard Replacement: step 5, image 2 of 3 Lenovo G70-70 Keyboard Replacement: step 5, image 3 of 3
      • Lift the back cover from the far side towards yourself to remove it.
      • Remove three 6.2 mm Phillips #0 screws.
      • The label M2X6 is written next to each screw that keeps the keyboard secure.
      Ask FixBot
    3. Lenovo G70-70 Keyboard Replacement: step 6, image 1 of 3 Lenovo G70-70 Keyboard Replacement: step 6, image 2 of 3 Lenovo G70-70 Keyboard Replacement: step 6, image 3 of 3
      • Turn the laptop over so the top side is facing you and open the laptop.
      • Carefully pry open any corner of the keyboard with the metal spudger.
      • Slide the metal spudger around the perimeter of the keyboard until you can lift it.
      • You will hear loud popping noises as the keyboard separates from the laptop.
      Ask FixBot
    4. Lenovo G70-70 Keyboard Replacement: step 7, image 1 of 2 Lenovo G70-70 Keyboard Replacement: step 7, image 2 of 2
      • Carefully lift the keyboard.
      • Use your finger or the opening tool to pull the locking flap toward yourself.
      Ask FixBot
    5. Lenovo G70-70 Keyboard Replacement: step 8, image 1 of 2 Lenovo G70-70 Keyboard Replacement: step 8, image 2 of 2
      • Pull the silver ribbon cable away from you to disconnect the keyboard.
      • Remove the keyboard from the laptop.
      Ask FixBot
2 other people completed this guide.
Joseph Crews
842 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 86
All Time: 685
