Lenovo G500S Touch RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
63
All Time:
1,131
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Every laptop comes with two sticks of Random Access Memory (RAM). Oftentimes, many users look to upgrade their RAM if they notice their computers acting slower than normal. The RAM is a component that is likely to fail, and some of those symptoms include: slow loading times, blue screen of death (BSoD), blank screen, etc.
If you’re looking to replace the RAM in your device, follow the steps outlined in this guide.
Tools
    1. Lenovo G500S Touch RAM Replacement, Battery: step 1, image 1 of 3 Lenovo G500S Touch RAM Replacement, Battery: step 1, image 2 of 3 Lenovo G500S Touch RAM Replacement, Battery: step 1, image 3 of 3
      • Make sure that your device is powered off and unplugged from the power source.
      • Flip your device over so that the back is facing you.
      • Using your fingers, push the tabs in opposite directions to eject the battery.
      • Remove the battery from the device.
      Ask FixBot
    1. Lenovo G500S Touch RAM Replacement, Back Panel: step 2, image 1 of 2 Lenovo G500S Touch RAM Replacement, Back Panel: step 2, image 2 of 2
      • Remove the three 4mm screws on the back cover using the Phillips #00 screwdriver.
      • Remove the back cover from the device.
      Ask FixBot
    1. Lenovo G500S Touch RAM Replacement, RAM: step 3, image 1 of 3 Lenovo G500S Touch RAM Replacement, RAM: step 3, image 2 of 3 Lenovo G500S Touch RAM Replacement, RAM: step 3, image 3 of 3
      • Push the silver hinges outwards to eject the RAM sticks.
      • Slide the ram out diagonally toward you and remove it from the device.
      Ask FixBot
    2. Lenovo G500S Touch RAM Replacement: step 4, image 1 of 2 Lenovo G500S Touch RAM Replacement: step 4, image 2 of 2
      • Repeat the same instructions from the previous step to remove any extra RAM sticks.
      Ask FixBot
Christopher Foster
512 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 63
All Time: 1,131
